Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: Wheel options
    Feb 2016
    Sydney
    Wheel options
    I have a 2008 GU6 with the 17inch factory alloys and 265/70/R17's (31inch)
    I am looking for a 33inch equivalent.
    It looks like a new 16x8 sunny with 285/75/R16's seems to be a well used combo and will be cheaper than the rubber alone on 17's.
    Good so far?
    The tyre shop tells be they recommend a -23 offset on the 16's.
    I believe my current offset is +10.
    Is offset mm? And if so, why would a 33mm change be needed for an increase from 265 to 285. Surely i only need to change 10mm and therefore a 0 offset. Or are brakes a factor?
    Just checking - a positive moves the inside rim nearer the engine and a negative moves away from the engine. Right?
    Thanks.
    Advanced abw's Avatar
    Jul 2015
    Sydney, NSW
    Yep, negative moves the tyre centerline out. I have ROH Trac2 16"x8" -13mm rims, with 285/75/16s. No rubbing and tyres don't hang outside the guards.
    Andrew
    GU3 Patrol, TB48, 33" muddies. front E-locker. 4.11 diff gears. 2.2 metre steel rack. Awning. Steel rear bar. Safari Snorkel. ARB side steps and brush rails. ARB Deluxe bull bar. Winch. 2" lift.
    Feb 2016
    Sydney
    Thanks abw.
    Did you go neg 13 for a reason?
    What year are you and ST or DX?
    Would a another 10mm still keep within the guards?
    Ta.
    Sent from my LG-H815 using Tapatalk
    Jul 2015
    Sydney, NSW
    It's a pretty common size, tyres don't hang out the guards. And ADR (?) rules say you can change the track legally (self certify) by 25mm over what is available for that model. Some Patrols come with 0mm offset, so having -13mm offset both sides changes the track by 26mm (close enough). By the way, I have the larger TB48 (4.8 L petrol) calipers, and these rims fit nicely over them.
    Andrew
  6. The Following User Says Thank You to abw For This Useful Post:
    besp (27th July 2016)
    330 Post(s)
    I went to Neg6 16x8 RockCrawler rims and run 305/70R16 (33x12.5) on them.
    The reference to neg 22 or Neg 25 is really carried over from the old GQ days when everyone fitting the Neg22 off the Toyota but it really is Too much for a late model GU as the tyres will be outside the guard and you risk being put off the road.
    My Neg 6 are perfect. I have seen Neg13 sit OK too but not sure they would take a 305 and still sit inside the guard.
    330 Post(s)
    check out this thread and go to post 10. Note the date is a long time ago and at that stage my GUIV had No lift and factory Alloys
    http://www.nissanpatrol.com.au/forum...Feedback-Kumho
  9. The Following User Says Thank You to MudRunnerTD For This Useful Post:
  10. #7
    Feb 2016
    Sydney
    Thanks guys. So neg twentysomething is not neededed for either big calipers or a wider 305 and might actually be an issue with adr's and protruding past the arches. So I think something around the neg 10 is the go.
    Anyone else want to share their thoughts?
  11. #8
    I recently fitted 305/70/16 on 16x8 neg 13 on a series 1 GU.
    Drivers side.
    Passenger side.
    This is with a 2" lift.
    Adjustable panhards will recenter the diff, but as you can see it's not a lot.
    Sent from my XT1068 using Tapatalk
  12. The Following User Says Thank You to jay see For This Useful Post:
    besp (28th July 2016)
  13. #9
    330 Post(s)
    Drivers side.
    Passenger side.
    I reckon you'd get done in Mansfield Jay see
  14. #10
    330 Post(s)
    These pics are 16x8 RockCrawler Rims with 'D' holes in a Neg-6 Offset and these tyres are 285s
