28th June 2016, 04:49 PM
#21
jay see
I had the same issue with my tb45. Thermostat wouldn't close all the way, stayed open about 2 mm. Once replaced all good. Just got back from driving around in tempts that didn't pass 8 degrees during the day and tempts were fine.
Sent from my XT1068 using Tapatalk
But it did get to normal operating temp didnt it ?????lol
28th June 2016 04:49 PM
28th June 2016, 05:12 PM
#22
@dom14 heres some 12mm "Ys" for your gas system , they will make your system
more efficient with less cavitation, If you need 10mm yell out as I have a link for them as well
http://www.ebay.com.au/itm/281878696...%3AMEBIDX%3AIT
29th June 2016, 12:36 AM
#23
threedogs
Yeah, with the new thermostat. When the old one was in it took longer to get to temp and when driving in he mornings during winter the tempts dropped only when on the freeway.
The Following User Says Thank You to jay see For This Useful Post:
29th June 2016, 06:57 PM
#24
I recommend you test the new thermostat before fitting it as I have had a brand new one fail.
The Following User Says Thank You to mudnut For This Useful Post:
29th June 2016, 11:26 PM
#25
mudnut
Was it an OEM or aftermarket one?
30th June 2016, 01:23 AM
#26
After market. But I still check any that I have bought since the failure.
30th June 2016, 11:38 AM
#27
mudnut
Ok, cool. I just remembered. I have two spare ones hiding somewhere. One is brand new, but can't remember whether it's OEM or aftermarket.
The other one is a used one I pulled out from a R31 Skyline from PickaPart few years ago. I just have to find them.
What is your method of testing them? Is it possible to test them on a bench that they function at the proper temperature rating?!
30th June 2016, 12:32 PM
#28
most would just place in a pot of water and bring them to the boil.
I have a good working OE thermostat here if required???
30th June 2016, 12:33 PM
#29
Just boil some water with the unit in it and watch it open, then close when you take it out. It just lets you know it won't get stuck as you can't pressurise the water to get the temp above 100 degrees.
30th June 2016, 02:52 PM
#30
threedogs
I'll see if I can find the ones I'm suppose to have here somewhere. If not, I'll drop in.
