Ok you lads with the big winches
whats best for in cab rocker switches
2seperate switches for in/out
or just one for in/out with an isolator
I can't really say that one way is better than the other, but I have got one isolating switch, and one in/out switch and it works very well.
Im the same with Winnie yet to wire mine in, but yes to an in cab winch isolating switch.
way too many low lifes that are over eager to cut any 4x4 in half,
Ive seen it done [end result] when the 4x4 show was at Jeffs Shed, grown men do cry sadly
blocko05 (24th May 2016)
Phones got a mind of its own today.
This is another way to isolate, 175amp Anderson plugs.
Works fine on Warn winch.
Also no live cables out front in case of an accident.
Macca
175aw is well short of what a 9000 pound winch can draw..
My 11xp can draw up to 500A.
But personally I'd fit an isolator switch out of the way.. in the gq it was next to seeing column.
The gu is down in the dash.
And fit the in / out in a handy location like center console..
The way I see it is you want to be able to sit back in your chair and push the in / out button with ease..
MudRunnerTD (24th May 2016)
Your right, and it has worked like this for 5 years in this vehicle and was in the previous one as well. Had a long extremely hard pull up a greasy hill, 3 or 4 times we ran the rope out and recovered another vehicle as well. The connection didn't get warm let alone hot. So I'm happy to keep it as it is.
Macca
For your winch power switch it could just be a toggle switch discreetly placed out of view, but
Once inside the cabin I don't think it really matters if hidden or not. Plus those winch in/out
switches are momentary on only for spooling in and out, take your finger off it and it will stop.
