6th August 2015, 06:47 PM
Administrator
Solar panels only use wet cell
My brother has a few solar panels and he noticed it says to only be used on open wet cell batteries.
He hasn't tried it in other batteries but can someone explain to me is this type of panel specifically designed to charge these type of batteries only and why, how?
They were purchased as an RV suitable panel.
6th August 2015 06:47 PM
6th August 2015, 06:48 PM
Administrator
They are 120w powertech model srs120m
6th August 2015, 07:08 PM
SUCH IS LIFE
I would think it would depend on the regulator that is used but I reckon you could charge any type battery, maybe not 100% efficiently but it would charge
________________________
______ 2017 D-Max _______
The Following User Says Thank You to Maxhead For This Useful Post:
6th August 2015, 07:12 PM
It's probably running a simple controller that's set up for wet sells. See if you can get a mppt controller which is in effect a smart charger that should be able to handle other types of batteries.
The Following 2 Users Say Thank You to Rock Trol For This Useful Post:
AB (6th August 2015), threedogs (8th August 2015)
6th August 2015, 07:55 PM
Administrator
Thanks gents, he's wet cells are now ruined after his kids left the camper lights on for weeks after a garage camping sleep over party whilst he was overseas and he doesn't want to go back to open wet cells hence the questions.
He also noticed a lot of acid coming out after a few bouncy touring trips and wants to change battery type.
7th August 2015, 09:04 PM
As others have said, get a proper PV regulator that's takes different battery types (wet, gel, agm) should work fine .. UNLESS the PV are low voltage and can't output enough for AGM's ..
Have to look at the spec's (open voltage, etc)
2004 4.2TD ST, Berrima Diesel Injector Tuned, Viper 3" SS exhaust, Cross Country Ultimate Intercooler, Solvaris sound proofing, DigOptions GPS/MMU, 220mm Roo Lights, PIONEER TS-D1602R 6.5" x 4 speakers, Autocar EGT&Boost gauges, Brown Davis 80L Aux, Icom 440, Alloy drawers and cargo barrier, 2" Amanda Extreme / Dobson / PolyAir lift, CSA mags with Toyo ATII tyres, Rhino Pioneer roof rack now with brackets, Performance 4x4 16g Large.
The Following User Says Thank You to HuskyInAuz For This Useful Post:
7th August 2015, 09:11 PM
Administrator
HuskyInAuz
As others have said, get a proper PV regulator that's takes different battery types (wet, gel, agm) should work fine .. UNLESS the PV are low voltage and can't output enough for AGM's .. Have to look at the spec's (open voltage, etc)
I'll have a good look at them when I'm over at his house next, cheers mate!
8th August 2015, 03:08 PM
I am he, fear me
Hiya AB,
The Powertech stuff I have seen comes with an onboard reg set for wets and has no other adjustment so not 100% ideal for AGM etc.
Panel specs 'should' be fine unless he has ended up with some weird array somehow.
Not sure about the "open" requirement you mention, that is a tad unusual and can't say as I have seen it before.
Whatever works on an open wet should work equally as well on a low maintenance jobbie 99% of the time
