Results 1 to 10 of 10
Thread: Camper mod needing 2m drawer slides
    584 Post(s)
    Haven't measured exactly yet just toying with the idea as you do on a Saturday night ;
    I have a modified Windsor pop top that is a few inches higher then standard, etc.
    I'm wanting to run slide out kitchen drawers on both the rear (underneath seating inside) and the front.
    I'll need roughly a 2m ball bearing slider though, has anyone done this or know of where to get them?
    Quality is the key here as they will get dust and I'm concerned of the lengthy runner getting jammed. Or do people run boxed timber with silicone tape etc for those lengths?
    Where is MudRunnerTD!
    If you need a hand cutting holes in your camper, I am there =)
  4. The Following 2 Users Say Thank You to Winnie For This Useful Post:
    AB (18th April 2015), rusty_nail (18th April 2015)
    2 metres !!!
    Is that 1 metre closed, 2 metres extended
    or
    2 metres closed 4 metres extended
    Be aware that the weight rating on slides isn't full weight at full extension
    Here is a link to the slides I used on my Camper (1500mm x 225 Kg)
    http://www.ebay.com.au/itm/1500mm-SU...item2331ae2c82
    Good vendor, awesome quality slide... have a search around on his site and you may find what you want
  6. The Following 2 Users Say Thank You to the evil twin For This Useful Post:
  7. #4
    584 Post(s)
    2 metres !!! Is that 1 metre closed, 2 metres extended or 2 metres closed 4 metres extended Be aware that the weight rating on slides isn't full weight at full extension Here is a link to the slides I used on my Camper (1500mm x 225 Kg) http://www.ebay.com.au/itm/1500mm-SU...item2331ae2c82 Good vendor, awesome quality slide... have a search around on his site and you may find what you want
    thanks ET I'll take a peak. I'm inly guessing mate, 1590 May be fine too.
    I'll do some measure up tomorrow.
  8. #5
    Patrol Freak lhurley's Avatar
    Oct 2011
    Brisbane. Manly West.
    Could always make your own runners.
    Get some box section ally of whatever tickles your fancy and some skateboard bearings.
    Attach the bearing either the draw or surround and the box section to the other. Mount the bearings so that they are too and bottom of the box section and alternate where the bearing on the top and bottom are, eg not all in line but a zig zag.
    I hope that makes sense. Rum is making words hard.
    1999 GU DUAL FUEL 4.5 - 2" OME - 33's KM2s - SNORKEL - CUSTOM DINTS.... Goes by the name Candy (the car not me )
  9. The Following User Says Thank You to lhurley For This Useful Post:
    AB (19th April 2015)
  10. #6
    Just copy the slide set up on my black widow drawers ab
  11. The Following User Says Thank You to MudRunnerTD For This Useful Post:
  12. #7
    Quote Originally Posted by lhurley View Post
    Could always make your own runners. Get some box section ally of whatever tickles your fancy and some skateboard bearings. Attach the bearing either the draw or surround and the box section to the other. Mount the bearings so that they are too and bottom of the box section and alternate where the bearing on the top and bottom are, eg not all in line but a zig zag. I hope that makes sense. Rum is making words hard.
    I was thinking this, but the braw back of this setup is you can get 100% travel. So say the kitchen is full width, 10% of it will be under the camper still so the runners can safely counter lever I'm bearings.
    The slides are a 3 stage, so safely go over the 100% with plenty of overlap in the slides for strength..
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    I might be able to still get these Andy which look the same as on ET's link: http://uesint.com/shop/steel-drawer-slides/
    PM me if you want me 2 get you a price
  14. The Following User Says Thank You to NissanGQ4.2 For This Useful Post:
  15. #9
    Yeah, probably same and price looks like similar quality if they are different manuf anyway.
    Don't fall for the trap of getting two lockables, 99% of applications you only use one or none.
    If both slides lock it means if you have something in your hand you want to remove/put in the draw you have to put it down to open or close the draw.
    You would be suprised how quickly that becomes a PIA
  16. #10
    Yeah, probably same and price looks like similar quality if they are different manuf anyway. Don't fall for the trap of getting two lockables, 99% of applications you only use one or none. If both slides lock it means if you have something in your hand you want to remove/put in the draw you have to put it down to open or close the draw. You would be suprised how quickly that becomes a PIA
    X2. Double locking is a pita
