Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: ZD30 loss of power
    check the brake light switch as the computer gets confused
    when getting mixed messages like brake light on and
    trying to accelerate at the same time
  2. #12
    What he said X 2... as prev posted it could also explain the CC problem.
    There are two switches on the brake pedal, check both
    It would have been a lot better if you mentioned that you had Dawes and Needle valve mods earlier as well
    Any other mods that may be an issue like chips etc?
  3. The Following User Says Thank You to the evil twin For This Useful Post:
    threedogs (3rd January 2015)
  4. #13
    The vac dampener goes in line from the vacuum pump...
