Page 446 of 1057 FirstFirst ... 444445446447448 ... LastLast
Results 4,451 to 4,460 of 10566
  1. #4451
    brisbane
    I used a 60 mm and the top bush retainer barely fit through it I'll put up a pic in a bit
  2. #4452
    brisbane
    Yeah I used a 50mm hole saw and cut the top out of the inner guards to allow access to the top of the shock the other week, need to take out some of the body lift and this will make part of it a little easier.
    Is your on a GU or a GQ? I’ve got no body lift and I had to slightly trim the tower on one side and the shock bush retaining washer is above the wheel arch and inside the engine bay.
    The passenger side was the easier of the 2 as the fuel filter bracket is on the driver side.
  3. The Following User Says Thank You to megatexture For This Useful Post:
    Ben-e-boy (15th December 2014)
  4. #4453
    Expert bishbashbosh's Avatar
    Nov 2014
    Well not much but i've finished all my dual battery system by just adding the final plug to the rear for solar panels and put up a webbing cargo net.. i know not many like the webbing nets but it works for my needs. Oh and i soaked my Burke & Will Nullarbor Swag twice and am just letting it dry in the sun.. I'm ready for the great outdoors nearly.. all whilst slamming some richie hawtin on the new speakers and warming up for a night at my local!
    Today is alright!
  5. #4454
    Patrol God Stropp's Avatar
    38 Post(s)
    Had the scrub bars fitted today
  6. The Following 4 Users Say Thank You to Stropp For This Useful Post:
    Clunk (16th December 2014), katwoman (16th December 2014), threedogs (16th December 2014), Winnie (15th December 2014)
  7. #4455
    Western suburbs of Melbourne
    12 Post(s)
    Had the scrub bars fitted today <img src="http://www.nissanpatrol.com.au/forums/attachment.php?attachmentid=52746"/>
    Doesn't she look purdy.
  8. The Following User Says Thank You to MEGOMONSTER For This Useful Post:
    Stropp (15th December 2014)
  9. #4456
    38 Post(s)
    Also swapped the awnings over so now have the 180 deg supapeg peg awning, I will see if I can get the tent and awning up in the next few days and get pics but she is off in the morning to get a few things finished prior to Xmas.
  10. #4457
    Jul 2014
    broke it no blinkers no rear lights no don't know which relay to check
  11. #4458
    Expert Agronaught's Avatar
    Sydney, NSW
    Washed it after a fun weekend away... I must have dislodged 30KG of clay and mud.
  12. The Following User Says Thank You to Agronaught For This Useful Post:
    Stropp (19th December 2014)
  13. #4459
    84 Post(s)
    I finally changed the clutch and brake fluid. There was blue fluid in the reservoir, but the fluid in the brake lines was a dirty yellow. So much for a full service by the car yard I got the Old Trol from.
  14. #4460
    Sydney, NSW
    Repaired the rear tail light thanks to a couple of cable ties. The Y61 rear end is the ugliest, most poorly designed, piece of crapolla out there IMHO. That it pops indicators if you drag it on the ground is a joke, I'm tempted to go a steel bar just to get rid of it :/
  15. The Following 2 Users Say Thank You to Agronaught For This Useful Post:
    jack (20th December 2014), Stropp (20th December 2014)
