Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: ZD30 CR Rebuild or Conversion?
    Patrol Guru rkinsey's Avatar
    Sep 2010
    Minchinbury
    Quote Originally Posted by Scottch View Post
    is it difficult to remove the engine and transmission in one piece?
    is it a done thing?
    Hey Scotch,
    The engine and trans together is able to come out in one piece. However, together they are very heavy and long. ( I would estimate my RD28T and trans would come in around the 600 - 700 Kg mark)
    I took out an RD28T with the transmission and transfer case connected and took me about 5 hours by myself (so get some mates to help you)
    Swapping the engine with another ZD30 would be the simplest method as you dont need any engineering certs to get it registered. Just a Blue Slip to change the engine numbers on the rego.
    If you are going to do the engine swap yourself, I would advise taking your time and 1000's of pictures of all connections. I would also label each connection to the engine from the wiring harness to the fuel and vacuum lines.
    If you can, get an engine and transmission together. I am having issues with my clutch and after installing the engine and getting it running I now have to drop the gearbox to fix the clutch.
    Cheers,
    Rob
    Just about to jump into my next Patrol. A 2001 GU II TB45E .
    WARNING!: Do not ever use a towball as a recovery point. They are not rated and can become a deadly projectile during a recovery if they snap off, and they have done so with tragic results in the past.
  2. The Following User Says Thank You to rkinsey For This Useful Post:
    Scottch (24th November 2014)
  3. #12
    Dec 2014
    Russia
    Please help.
    On Patrol "dies" second engine ZD30DDTi. The first native passed - 200000 km Second set from Nissan Elgrand passed 80000 miles. Now introducing from Nissan Caravan system common rail. The question arose for the replacement of the wiring of the engine, the desired number on the underhood wiring the controller number is 23710VZ25D. Engine number 10100VZ20C.
  4. #13
    Dec 2014
    Russia
    No one will help ?
    Need VIN on car NISSAN PATROL ZD30 CRD? If you need to order the scythe(wiring) on the engine.
  5. #14
    Apr 2013
    Moss Vale NSW
    Quote Originally Posted by Extrimal D View Post
    No one will help ?
    not sure what ur triyng to do?
    my VIN on C/CH 08 CRD Patrol is JN1UELY61A0500968 if that helps???
  6. #15
    Dec 2014
    Russia
    Thank you very much. Right now I'm going to check through EXZIST. If all is well will order new wiring.
  7. #16
    469 Post(s)
    The simple answer is you can fit anything to anything... if you have the money and someone to sign off on it.
    To fit a TD42 to a late series GU, where the TD42 was not a factory option, you need the modifcation to comply with ADR's etc but the big stumbling block is emissions regs.
    The TD42 was discontinued for several reasons but emission compliance issues was one of them.
    To pass the emissions regs you need the vehicle modified before it can be tested and signed off.
    If you can't get the signoff then you are out big bucks.
    I don't know of anyone doing CRD to TD42T mods and I haven't ever seen one for sale or the service advertsied but Hodge may well be correct and someone may be doing them.
    ET. The TD42Ti has all the emission controls on that motor. The earlier TD42T's don't. But still not sure if it would make compliance or not for the OPs year model Patrol. It would certainly be something worth the OP checking out if he's serious. As you wouldn't NOT want to put the TD42Ti in only because you were told you can't, then find out you actually can... Not saying the he can or can't. Lol. Just saying check it out and get a definitive answer.
  8. #17
    Dec 2014
    Russia
    While the CRD is not common rail?
  9. #18
    Dec 2014
    Russia
    Guys and pin scheme of this kind of engine control unit no who?:
  10. #19
    176 Post(s)
    CRD is common rail. "Common Rail Diesel".
    Advanced Scorpiovee's Avatar
    Sep 2014
    Melvegas
    Getting the 4.2 modded to pass emissions is possible but very very expensive. For similar money, you'd be better off going for the Chev 6.5lt diesel.
    Still not cheap though.
