Gus,
No - it would be extremely unlikely that the sensors are faulty if they work on the other car.
I would be tracing the wire back to the ECU from the sensor, and make sure that it is reading the same value as it is at the sensor with a multimeter.
If the cars are identical, you could also try swapping the main ECU
