Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: **trailer brake lights not working**
    Expert Warwick89's Avatar
    Oct 2013
    Cairns
    Post **trailer brake lights not working**
    Just put my camper on to take it for a drive and the brake lights don't work, tried the box trailer to check and those brake lights don't work either. Tried the missus car and the trailer lights worked.
    I've unplugged the connections on the car cleaned and replaced and still nothing tested with a multi and it read 13.5 on the breake light pin so I'm at a loss.
    If the pin is getting the power and there isn't anything wrong with the trailer what could be going wrong?
    Thanks in advance
    Warwick
    Oct 2013
    Cairns
    I should mention I need to fi this tonight because It's the last chance I have before we hit the road
    2010 GU7, ZD30 CRD. ARB: bulbar, scrubbars, rock sliders, roofrack, front and rear air lockers, twin compressor. OME 2" lift, mickey T's ATZ P3 33" tyres x 6, opposite lock rear twin spare rear bar, Wurton 46" light bar roof mounted, draw system, clearview mirrors, redarc gauges: boost, EGt, engine pressure and temp, trans temp, battery. Dual battery system, 12,000lb warn winch, DYI sound/heat proofing.
    Patrol Freak lhurley's Avatar
    Oct 2011
    Brisbane. Manly West.
    The plugs not dirty, or lose? Both trailer and car side.
    Is it a new plug?? Could be wired wrong.
    1999 GU DUAL FUEL 4.5 - 2" OME - 33's KM2s - SNORKEL - CUSTOM DINTS.... Goes by the name Candy (the car not me )
    brisbane
    Did you check the earth pin ? Do the rest of the lights work ? Bit odd if its only the brakes
  5. #5
    Oct 2013
    Cairns
    Quote Originally Posted by lhurley View Post
    Plug hasn't been changed on either trailer and it's very clean
  6. #6
    Oct 2013
    Cairns
    Quote Originally Posted by megatexture View Post
    Yep all lights work on both trailers except for the brakes but they work when I use a different car so I has to be car side. Just confusing me because it's getting power and it's clean and tight I've redone all connections on the plug and still nothing. I'm about to smash something haha
  7. #7
    Oct 2013
    Cairns
    I don't see how it could be an earth if everything else works. I'm at a lose now I don't know what to do
  8. #8
    81 Post(s)
    Since the trailer lights work when connected to the other car, the fault is in your car. It could be a high resistance connection behind the socket, or where the wire taps into the brake light circuit, especially if scotch locks were used. Try a bit of crc or wd40 on the plug and socket, it sometimes works. Also check the resistance between the socket earth pin and the car chassis, it should be close to zero ohms.
  9. #9
    brisbane
    Ye not earth pin if the other lights are ok .
    Is the brake pin firm in the female end and ring on the male it could be getting pushed away when you plug it up, just try pushing on them... Its going to be something simple and you will kick yourself lol
  10. #10
    Patrol Freak gaddy's Avatar
    redlands
    Has it got those dumb a$$ scotch clips joining the plug to the the harness , they are renowned for failing to make a solid connection
    Opps just saw mudnuts post
