I used to use discarded cast iron BBQ plates in an angle iron frame.
Then welded a 1" plumbing socket in each corner with screw in legs about 400mm long.
All pulled apart and housed in a hessian bag or similar. M2cw
Keen to see how this turns out.
No pressure Westy...
BigRAWesty (9th December 2013)
I can put up a pic of how the legs on mine work if you like
Ok thought I betta close a thread..
Here are the finished products.
So in the end I like the flat side over the Rod side..
Enjoy.
FNQGU (8th February 2014), megatexture (7th February 2014), P4trol (7th February 2014)
Both look great mate, IMO I like the flat also I think it would be more solid to put a loaded camp oven on if wanted. Though slimline would pack nicely lol
BigRAWesty (7th February 2014)
Flat also catches snags b4 they fall lol
BigRAWesty (8th February 2014)
if that's no to your fancy just use a cast iron BBQ plate in an angle iron frame.
weld sockets in each corner and cut 4 legs to either screw on or slide in
will put pic soon
