Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 57
Thread: Dual 12v compressor and air tank upgrade
  1. #21
    Feb 2012
    "Hiding Under Your Bed!"
    30 Post(s)
    watching this with interest as I have a 9L and 4L airtank at home to install and not to sure of the piping it came with, bought some 225psi rated hose to use instead
    www.swat4x4.com
  2. #22
    Expert sil3nt_dr3ams's Avatar
    Mar 2013
    Rated to 240 degrees and 300psi that's why they are stainless braided?
  3. #23
    Feb 2012
    30 Post(s)
    SD, might have to tap into your knowledge when I get ready to mine or find someone in Perth so I can have a gander at 1 installed
    Sent from my iPad using Motorculture mobile app
    www.swat4x4.com
  4. #24
    brisbane
    Looks can be deceiving the one in my pic is stainless 90deg and 145 psi, whats a length of that one worth line.
    Gonna be a sweet set up though will be interesting to know how fast it's going to do 18- 40 psi in comparison to others. Should be a walk in the park
  5. #25
    Mar 2013
    Quote Originally Posted by megatexture View Post
    Lol we talk bout that shit later mate, I'm about two hours away from being finished. Im just bolting the compressor in atm. remove front expose the conduct with my other compressor power feeds and add new one back to battery. Drop in another relay next to the other compressors relay double the switching wires and run another power feed to battery.
  6. #26
    Mar 2013
    Quote Originally Posted by oncedisturbed View Post
    Lol looks like i have been nick named. SD, can live with that been called worse. Mate Im 450km north of you Geraldton , lol come up have a look always cold piss in the fridge and a place to roll a swag out.
  7. The Following User Says Thank You to sil3nt_dr3ams For This Useful Post:
    oncedisturbed (28th October 2013)
  8. #27
    Mar 2013
    These thumper are unreal I've been using the first one flat out for nearly two years and I run my nail guns at work with it.
    Cylinder: 60mm
    Voltage: DC 12V
    Air Flow: 160L/min
    Maximum pressure: 150PSI
    Maximum amperage: 45A
    Can be hard wired
    Auto reset thermal protection
    Heavy-duty 2m power cord with battery clamps
    Features built in circuit breaker and automatic thermal cut-off
    8m nylon hose with inline pressure gauge
    Maximum voltage: 13.8V
    Maximum amp draw: 45A
    Maximum restart pressure: 150PSI
    Maximum operating temperature: 140°F
    Minimum operating temperature: -67°F
    Will have a switch to run either one or two compressors.
    According to the maths should be 11.3cfm
  9. The Following 2 Users Say Thank You to sil3nt_dr3ams For This Useful Post:
    cgm (28th October 2013), oncedisturbed (28th October 2013)
  10. #28
    Mar 2013
    Eerything is wired in and running perfect, so how are we going to test this setup?
  11. #29
    Feb 2012
    30 Post(s)
    Definetly a neat set up
    www.swat4x4.com
  12. #30
    Mar 2013
    Mate the setup its self isnt hard at all. Its the time and effort that goes into each fittings and each wire. Fuses relays. I've been working on my base wiring system for months . I'll upload some pics in a minute
