Results 1 to 10 of 11
Thread: my patrol's on the piss!
    Sep 2013
    just got new shocks and springs on the GQ....now the driver's side is 15 mm higher than the other.
    is this normal??( the springs are on the correct side......ian
    Hi Ian,
    Please head over to the Introduction section and post a Hello thread please mate. We like new members to say G'day before asking for advice.
    How does it sit with you sitting in the car?
    Patrol Freak Parksy's Avatar
    Jan 2013
    Nowra NSW
    5 Post(s)
    Hey mate, head over to the intro section and say g'day. Just a small ask of this forum. You will find lots of people will offer all the help once you've done this. Friendly bunch here.
    583 Post(s)
    Mine is slightly higher on the drivers too. I assumed its the weight compensation of the driver plus other things on the drivers side (battery, fuel tank if on side, torque of the motor, spare wheel, etc).
    As above, jump in and get someone to see how it looks.
    Welcome to the forum as well mate and don't forget to put up an intro about yourself in the intro section.
    I actually wouldn't mind seeing how my GQ sits when I'm in there...lol
    43 Post(s)
    It would loose value...
    Welcome mate. As others have said it's pretty normal. Was it meassured straight after fitting or after a few k's to seat them in??
  7. The Following User Says Thank You to BigRAWesty For This Useful Post:
    AB (1st October 2013)
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    Before you installed the springs, did you put them side by side to select the longer one? This normally goes on the left hand side to allow for road camber. That way your vehicle sits level as its going down the road and it is also easier to set up the wheel alignment.
    Sep 2013
    that seems logical to me...but the long springs are marked : R/H .....they are king springs which may be made in China where they drive on the wrong side???
  10. #8
    Sorry Bill that's not correct mate. Makes sense but is inaccurate. The long front spring is for the Drivers side to support the weight of the driver as part of the constant load and also the spare wheel on the drivers side rear door. If you also have a sub tank it's on the drivers side.
    Longer Spring should be clearly marked if they are New and be for the Drivers side.
    The 100,000km old OME kit I just lent Mego still had the paper wrap label identifying it for the drivers side.
  11. #9
    Sep 2013
    should also mention long-range fuel tank is centred...ian
  12. #10
    43 Post(s)
    And they will also be stamped /engraved
