Patrol not starting on the first crank after the glow light has flick off.it takes now around 4-6 sec s to start with a white/grey smoke puff.with no more smoke visible once it has started .this is my first diesel
Marcus,
Check your glow plugs....I would say that you have one or some that are faulty.
Mic
I'm in the same boat with my 3ltr... Only just started happening...
when replacing glow plugs dont get the cheep ebay ones you will be back for another set in no time, Look at either genuine or ngk.
Testing is easy. remove glow plug and hook up to 12v and see if they glow red hot if not replace
My 3ltr was not starting first hit and thought it was injectors etc, with the cold weather
the problem showed up this morning did not start at all, had to jump off the AUX battery.
The cold weather will show up any battery that's on the way out.
glow plugs is the issue, spend decent money & buy quality, there are many many cheap rubbish ones out there, $60 plus each will fix the problem, cheaper versions will eventually play up, ring Berrima Diesel for recommendations on brands
2002 3L GU Patrol, 2" lift, 33's, snorkel, dual battery, sliders, DVD, bluetooth
Might also need to check your battery out.
