Unfortunately I have to sell my 1997 GQ RD28T Wagon 5 spd manual due to changing circumstances at home and the rebuild for the Patrol can no longer be afforded.
So here is my truck. It is unregistered and will not come with a RWC (it will pass one though). I'm asking $4500.00 as is.
The car runs and drives fine. I took it off the road in December 2012 due to power loss and overheating issues. The overheating issues come from a stuffed radiator and it will need to be replaced. I have already replaced all of the radiator hoses and thermostat housing.
Interior is in good condition and there are no marks or tears in the seat upholstery (other than normal wear from a 16 year old car)
The power loss is coming from the fuel injector pump that needs servicing (I think) the turbo is still boosting at 8 psi (Factory turbo)
I rebuilt the top end of the motor with a new head and timing chain assembly and the engine does not leak any oil at all. There is no rust in the chassis or body except for a very small spot in the middle of the front edge of the bonnet (the previous owner had a stone guard on it that was rubbing) only very minor surface rust. There is no rust in the rear side sliding windows and all window and door seals are in good condition.
AC needs a new tensioner pulley (the bolt that holds the pulley on fell out)
I run it every week. (in the backyard) and it does blow a little smoke. I was informed by Westend Diesel that the rings will need replacing.
It comes with the following:
ARB steel bull bar
8000lb Warn 8274 Hi Mount winch with 28m of 10mm steel cable. (Needs a replacement solenoid)
Crystal 7" headlights (Semi Sealed)
Nite Stalker spotlights
Oricom 40 CH UHF radio
3db and 6db gain aerials
CD player, AM/FM radio
3rd row seats (7 seater) in very good condition
Steel Cargo barrier
4 x brand new Maxxis Bighorn mud terrain tyres on 15" rims
Power mirrors
Central locking
Power Steering
Air Conditioning is cool (Need to replace the AC tensioner belt pulley)
HR Tow bar
Sidesteps
296801 Km on the clock.
Located in Western Sydney.
PM me for contact details or if you would like to inspect.
Regrettable sale but has to be done.
Cheers,
Rob
