Results 21 to 30 of 44
Thread: GU TB45 Wagon on LPG
    Advanced tricksgonefishing's Avatar
    Esperance WA
    Food for thought, I have a 98 GU TI duel fuel and I wanted to fit a duel battery so I chucked out all the factory air box and shit and made a s/s 3" snorkle with a scoop across the top of the windscreen that has a narrow panel filter in it (the same as the ones used on V8 holden OTR intakes) and now I get a lot better fuel ecconomy on petrol but on gas it stalls every time I back off the throttle to coast up to a corner. I put a vac/pressure diagnosic gauge on the intake duct next to the gas mixer and at 30km/hr with my foot off the go pedal it was showing +0.12 bar and I think that pressure is upsetting the LPG flow.
    If it does'nt go hard, Stroke It.
  2. #22
    Expert twisty's Avatar
    May 2011
    ACT
    Quote Originally Posted by tricksgonefishing View Post
    I had the same problem. Slowing to a corner engine leans out and stalls. Fixed it by turning the snorkel inlet to face backwards. Not so easy for you.
    25+ city/highway, 90 litres useable lpg (115l tank). 2" lift, standard AT tyres, alloy rack, no drawers or other heavy objects (water etc). I've seen 3 different (and recommended) lpg specialists, valves done regularly, new condensor, plugs, leads etc. Always the same economy for the last 3 years.
    GU1 Auto ST4500 lpg/petrol.
  3. #23
    getting the car tuned tomorrow so I am hoping for some magic
  4. #24
    May 2011
    ACT
    Quote Originally Posted by fmacdonald View Post
    Hogwarts lpg specialist?
    good luck. curious to know what you get done.
  5. #25
    Dec 2012
    Depending on the setup you can connect a balance pipe back to the converter top stop this happening.
  6. #26
    The 4x4 place I went to checked the valves, filter, leads, plugs and advanced the timing. They suggested the plug I am using are not ideal but did not expect there to be any impact. Not expecting any change but will know after the next fuel fill up. If no luck I will go to "The Gas Man" in Seven Hills, NSW. Anyone used them?
  7. #27
    Now running at 30l/100km ... have pointed the snorkel backwards ... expecting no difference but what harm can it do
  8. #28
    Patrol Freak lhurley's Avatar
    Oct 2011
    Brisbane. Manly West.
    Should be able to get it lower then that. I drove mine from brisbane to melb and back and got in down to 17L/100km. Reset everything (disconnect battery) and then take it for a long drive. Obviously not a 4000km drive but something to get it to relearn properly.
    1999 GU DUAL FUEL 4.5 - 2" OME - 33's KM2s - SNORKEL - CUSTOM DINTS.... Goes by the name Candy (the car not me )
  9. #29
    How did you figure out the 32/100 k part, that's like 300k a 90 ltr tank on ULP
  10. #30
    Quote "Should be able to get it lower then that. I drove mine from brisbane to melb and back and got in down to 17L/100km. Reset everything (disconnect battery) and then take it for a long drive. Obviously not a 4000km drive but something to get it to relearn properly."
    I will give this a go this weekend
    I typically fill up at 250kms however I just fill up each time and work out the L by the km driven, eg last week I filled up and got 74.8l with 249km travelled.
