18th July 2013, 04:57 PM
Mounting a winch in genuine bar
Hey all
I just bought a 2011 Y61 Patrol that has a factory steel bar and have tried fitting a winch but there is nothing to mount the winch on. Is there a cradle that i need to mount the winch on. There is a place for the fairlead but thats it. I have called a few Nissan dealerships and they said they have no idea.
I need some guidance.
18th July 2013 04:57 PM
18th July 2013, 05:04 PM
Is it a winch bar mate???
18th July 2013, 05:07 PM
Yeh mate genuine winch bar. I think its called a deluxe bar.
18th July 2013, 05:09 PM
You'll have 2 captive nuts under chassis on both sides the winch "cradle "will bolt to that.
Plenty for sale on Ebay, petrol or diesel
18th July 2013, 05:14 PM
Yeh they all say for alloy bullbar, so i take it that its the same thing.
18th July 2013, 05:18 PM
Don't they bolt to the rear of the bar? There should be 4 threaded nuts welded to a plate on the opposite side.
LESS YAP YAP, MORE TAP TAP!!
18th July 2013, 06:09 PM
Photos mate... that helps
18th July 2013, 06:55 PM
Moderator
Mine bolted straight in. Well upside down and flipped but bolted through the bar.
Top 2 bolts through the bar above the fair lead hole and the lower 2 go through the fair lead and holds itin place as part of the mounting.
Take off the lower plate cover from underneath and you should be able to bolt it straight up mate.
Check out my Toy -->
Rogue Dung Beetle
harrythomas (2nd August 2014)
18th July 2013, 07:25 PM
Exactly. That's how I installed mine. It's a bit of a bitch to engage due to the positioning. I also have the genuine Nissan winch bar.
As a point of interest, have a look at the compliance tag. You'll notice it states that only a warn xp9000 is to be fitted.
18th July 2013, 07:28 PM
Moderator
I have fitted an x9 Super Winch off a 200series cruiser (Toyota factory fit winch)
Rogue Dung Beetle
