E-FAST helps you find parts needed for Nissan vehicles and create parts lists to be printed or transferred to your in-house computer system. After you find needed parts and create a parts list, you can save it and later restore it for recommended maintenance or any other common service.
Parts for most pre-1979 models are available in E-FAST. About Fast For Windows
FAST for Windows helps you find parts needed for Nissan vehicles and create parts lists to be printed or transferred to your in-house computer system. After you find needed parts and create a parts list, you can save it and later restore it for recommended maintenance, a service campaign or when a kit isn't available.
Parts for most models manufactured since 1979 are available in FAST
Enjoy!
Todd
Edit 24/07/2014
Before downloading this software be WARNED
About a year ago my virus program picked up one of the files in the setup zip file as containing a virus, hence why this thread disappeared. I have been running this program for years without any known virus issues. I downloaded the setup files again tonight and they came back clean.
So download at own risk and make sure you virus scan before installing
The Following 6 Users Say Thank You to NissanGQ4.2 For This Useful Post:
AB (29th November 2012), Dirtydog16 (18th February 2012), harro959 (12th November 2012), JoseM (12th December 2012), Perona (3rd December 2019), Robo (6th December 2012)
Step 5 - Run Nissan Fast 1. Select the short cut Nissan Menu on the Windows Task Bar
2. If it asks you to run a file called NFUdate.exe select YES, it will then go through an install procedure before opening the Nissan Fast Menu
3. Select the Fast System Icon
This will open the Main Nissan Fast Window
If you have AR 1 showing then you have the Australian Catalog working, now you can sit back and have a few
The Following 9 Users Say Thank You to NissanGQ4.2 For This Useful Post:
89GQ (4th February 2012), Dapple (28th February 2012), Dirtydog16 (18th February 2012), Fity (23rd March 2012), harro959 (12th November 2012), im2xtreem (14th August 2018), JoseM (10th June 2013), Robo (6th December 2012), the evil twin (16th January 2011)
I have got e-fast to work. The file tdbg6.ocx is required to be placed in the install directory. However there is no patrols. Here is a screeny of E-fast. But still working on it.
Thanks mate, as far as I'm aware E-Fast is only for Early model Nissans so might not cover the patrols. But I'm only taking a guess on that, only new to Nissan Fast and E-Fast, so learning as i go
Thanks again Dhuck, I owe you a beer. Why are you using E-fast anyway, If you can't get your info from the Fast System, u certainly won't get it from E-Fast
Beer sounds good. I am an IT freak (not geek) and will try just about any software to see what it does or how it works. Besides I do have an N13 Pulsar as well as several other cars (not Nissan).
I did notice that windows 7 is not mentioned above. has anyone tried a win 7 install yet? Or does anyone know if I need a patch to work with win 7 or if i need to run win 7 backwards in some sort of compatibility mode? I haven't tried to use it yet but am downloading it now and am interested as I only have win 7 on the pc, laptop and netbook here.
