Anyone have problems with GU door pocket mesh stretching ?
Both of mine are stretched. Just wondering what others are doing to fix the problem.
Is there a better replacement or do I just cut them off ?
Hi
I had the same problem and after consideration I just cut them off
mine to they just get in the way
Thanks guys. You've confirmed what I thought. I'll do the same.
cut the dambn things out of mine the day i got it. can you get replacements????
mine had stretched to ,got a hot glue gun folded the mesh to one end so it was tight and glued it ,looks tidy still stretches holds things in place tried to put some pics in so that you can see but for some reason not working
5 months and still holding ok
