Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 52
Thread: MQ /MK differences
  1. #41
    Napier, NZ
    Thanks MQ, do appreciate your advice, I'd be up that creek smelling like a dunny otherwise lol
    Whoever disagrees with the saying "Might is right" obviously doesn't own a MQ
  2. #42
    Patrol God Finly Owner's Avatar
    Jul 2010
    Waterford West Qld
    The ruond bulb from your MQ is called a "Sealed Beam" Headlight. The MK one is a " H4 Halogen BulB" Headlight.
    These both types come in round and "square" headlights in all the common sizes.
    Tim
  3. #43
    Napier, NZ
    Thanks for that Tim, I'm intending to retain the MKs head lights when I do the body swap as don't want to stuff around making mods to fit the round headlight. I'm assuming that all I'd have to do is change the bulb over from 24 to 12.
  4. #44
    Jul 2010
    Waterford West Qld
    Quote Originally Posted by aussiemale View Post
    correct you are
  5. #45
    Oct 2013
    Will the mq front quarter panels fit on the mk. I know the mk has the extra supports running from the window forward does that stop the mq panels fitting?
  6. #46
    Expert Lawrence's Avatar
    St Thomas, Jamaica
    Mk has rubber bushing for springs (as well as different type springs), while mq had steel greasable bushings. I had to change mine (87 ute) out to the steel ones as one of the front springs had broken on mine and dealer ordered the mq springs. They have different amount of springs according to the spec rather than the year i think, My ute had 3 springs per pack at the front, whereas i have seen a deluxe wagon with around 6 springs per front spring.
    1989 Nissan Patrol DX with the td42 (inline pump). No mods yet except black US 16x8 rims with 265 75 16 Ats
  7. #47
    Feb 2011
    Central Coast NSW
    Combination switch has different plug
    mk
    mq
  8. #48
    Mar 2014
    Perth
    I have a 4spd mk l28 it was the last 4spd built before the switch too 5spds. Only about 4 months between the last 4spd and a 5spd upgrade on the mk, can get a little confusing.
  9. #49
    Mar 2015
    look like a great project. Very informative stuff bud! Thanks wasnt sure which model i had.
  10. #50
    Dec 2018
    Italy
    perfect thread, i bought my patrol in a hurry and only now seem to know its model number.thanks
