Results 1 to 6 of 6
Thread: coolant leak
    Expert ozzyboy's Avatar
    Oct 2011
    springwood, qld
    coolant leak
    noticed this morning coolant leaking out of head, at the 2nd pipe from the firewall.
    sorry about the photo quality
    [IMG][/IMG]
    has anyone seen this before, or know how / why it is leaking from here?
    the pipe comes from the radiator top hose, which has a junction feeding 6 lines to the head.
    tb42e gq
    any help appreciated.
    cheers
    ozz
    Expert MudDonk's Avatar
    Underwood
    dunno ozzy dont look good though any ideas guys?
  3. The Following User Says Thank You to MudDonk For This Useful Post:
    ozzyboy (17th February 2012)
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    Give me an hour Oz and I'll be home - can have a look then (give me a call around half seven).
  5. The Following User Says Thank You to Bigrig For This Useful Post:
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    So it has had the aftermarket cooling put through the head...not sure what method is used to fit the pipes into the head. Are they threaded and tapped into the head? Maybe just leaking around the thread? Are they braised in?
    Hello from Under Down Under!
  7. The Following User Says Thank You to taslucas For This Useful Post:
  8. #5
    Patrol Guru rottodiver's Avatar
    Nov 2011
    Perth
    hope it works out ok for ya...... fancy looking cooling system!!!!
    Scotty
  9. The Following User Says Thank You to rottodiver For This Useful Post:
  10. #6
    Oct 2011
    springwood, qld
    will get in and take a good look once the sun comes up.
    cheers
    ozz
