Page 16 of 98 FirstFirst ... 1415161718 ... LastLast
Results 151 to 160 of 974
Thread: Nissan Patrol Full Factory Original GQ Service Manual.
  1. #151
    Feb 2011
    Shed
    45 Post(s)
    Quote Originally Posted by toddrhind View Post
    Sorry Andy, didn't even think without the 25 post rule applying that none members couldn't download the pdf 2 get the manual, I should of asked first. Was 2 focused on why Peter couldn't access the manual on his mac
    Me bad.
    Thanks boss 4 removing them
    I think you'd better sit in the corner and face the wall Todd tut tut tut
  2. #152
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Quote Originally Posted by growlers71gq View Post
    hahahahaha.......yeh that's probable a good idea *L*
  3. #153
    Jun 2011
    Adaminaby, NSW, Australia
    The manual is exactly what I need. I have a GQ with 325,000klms & have just struck my first problem with the engine warning light. Could be that I have used E10 for the first time.
  4. #154
    Quote Originally Posted by GedB View Post
    Welcome to the forum mate, glad you found us.
    Don't forget to put an intro about yourself and yoru rig in the introductions section and feel free to ask any questions mate.
  5. #155
    Aug 2010
    17 Post(s)
    I have used E10 since it was introduced and never had a problem with the engine warning light
  6. #156
    Hardcore 04OFF's Avatar
    Brisbane,QLD
    12 Post(s)
    In some cars/situations the E10, due to its chemical make up, does not get combusted 100%, the left over fuel residue goes out the exhaust, and gets collected by the Catalytic Convertor, where it can slowly burn and destroy/block a Ceramic Cat in no time.
    Later model cars designed to run E10 have metal core cats ,not the older ceramic type, cats with higher CPI (cells per sq inch) can be more susceptible to blockage.
    Id stick to regular unleaded (what you car was designed to run on)
    Check for a blocked Catalytic Converter, an easy way is, if you can unbolt the exhaust before the Cat to relieve the exhaust gas, then see if engine will rev or gets more power back.
    If the Cat is the problem, the blocked exhaust will most likey have triggered a faulty O2 sensor/engine check light.
  7. The Following User Says Thank You to 04OFF For This Useful Post:
    NissanGQ4.2 (16th June 2011)
  8. #157
    Apr 2011
    Broken Hill - Merbein - Pooncarie
    Howdy Ive tried opening the Manual byt all I can do is get to a page that says
    Click below to download the GQ Nissan Patrol service manual
    LINK REMOVED BY AB
    but nothing happens?
  9. #158
    Feb 2011
    Shed
    45 Post(s)
    its quite a large file so may take a liltl bit of time to download mate :-0
  10. #159
    Quote Originally Posted by Crowman23 View Post
    LINK REMOVED BY AB
    Hi mate, I just removed that link so only members who sign up have access to it.
    The file is 109mb but if you click on it, then it will be a blank page and can take some time to download depending on how fast your internet is.
    You should be able to see at the bottom left of the page the status of it downloading....Example: 2mb of 109mb, etc...
  11. The Following User Says Thank You to AB For This Useful Post:
    Crowman23 (22nd June 2011)
  12. #160
    Jun 2011
    i have tried to open the link for the patrol manual but it does not open help!
