Results 1 to 2 of 2
Thread: Soft clutch pedal
    Expert HippoNZ's Avatar
    Feb 2011
    New Zealand
    Soft clutch pedal
    Hi guys
    Am starting to notice the clutch pedal becoming softer and softer, can anyone confirm where the master and slave clutch cylanders are located so I can make sure the oil levels are right. Also any other reasons to a soft clutch would be appreciated.
    thanks in advance
    Brett
    Patrol God nowoolies's Avatar
    Perth
    g`day Brett
    straight in front of the driver under the bonnet
    big (usually black) booster for your brakes
    and along side of that you will find the master for the cluch have a look at the colour if dirty full flush required
    if low top it up
    if you havent had any adjustment done on the cluch you might be able to take some slack up there
    Tony`s the best to help with that though
    usually the cluch goes soft after a lot of wear or unless your outta fluid
    HELL NO !!!!!!
  3. The Following User Says Thank You to nowoolies For This Useful Post:
    HippoNZ (11th June 2011)
