Results 1 to 6 of 6
Thread: Diffs
    Advanced PT Paul's Avatar
    May 2011
    Ipswich
    Diffs
    Hey Guys. Is it me or are the diffs on my GQ just massive. Is bigger stronger? What's the story?
    Patrol God nowoolies's Avatar
    Perth
    strongest in the 4x4 range
    HELL NO !!!!!!
  3. The Following User Says Thank You to nowoolies For This Useful Post:
    PT Paul (10th June 2011)
    Expert HippoNZ's Avatar
    Feb 2011
    New Zealand
    Quote Originally Posted by nowoolies View Post
    x2 there bloody strong, are very sought after on customized 4x4s
  5. The Following User Says Thank You to HippoNZ For This Useful Post:
    The front diffs on GQ Patrols (H233b high pinion) are big, substancially bigger than the front diff on a Cruiser (which itself is the same size as a Hilux rear diff) size does matter and they are very strong. GU Patrols have the same front diff as GQ but with bigger/stronger CV joints.
    GQ rear diff is the same size as the front (H233b low pinion) and also very strong. I have seen a few broken back axles but the vehicles were FAR from standard and being treated very roughly. Some GU Patrol wagons were fitted with an even bigger rear diff, the H260b. These are as good as unbreakable.
    Tony
  7. The Following 4 Users Say Thank You to YNOT For This Useful Post:
    HippoNZ (9th June 2011), katwoman (8th June 2011), PT Paul (10th June 2011), Woof (8th June 2011)
  8. #5
    May 2011
    Ipswich
    Thanks guys thats awesome to know
  9. #6
    if you spoke to any Toyota owner that knew anything about 4x4s and they were being honest they would tell you that their Perfect 4x4 would be.......
    Their Toyota body on your GQ or GU Chassis and Drive Train as it is simply the Strongest in the passenger vehicle range. That is why the Comp guys rarely choose a Toyota for the serious stuff.
    Next time your standing around a fire at night with a Toyota owner tell him about that and see if he will put that in his pipe and smoke it......
    TOY OTA
