Page 84 of 87 FirstFirst ... 8283848586 ... LastLast
Results 831 to 840 of 861
  1. #831
    No flow was caused by an airlock in the horizontally mounted WTA coils I have on the roofrack. I stuffed around with all sorts of analysis and theories and in the end grabbed the garden hose and push water thru the circuit which totally took the air out but sent a pile of green coolant down the drain. Anyway, pump is circulating at 9LPM at a pressure of circa 5-6psi system resistance. At ambient radiation in the driveway the coils shed around 5 deg, and circa 14 degC with the 4 fans running. The aeroflow pump is rated at 40LPM open flow, so this will give an indication of the actual performance you can get in reality from the claimed specs. I am going to add a ball valve before and after the pump to allow for a more efficient pump isolation and swap out when and if it happens - previous performance with the Aeroflow was poor, but am willing to try it again as have it in hand.
    I pulled the previous gear pump out and apart, seems fine, reassembled and then bogged it up to make it watertight, powers up fine, will see if it goes back into service or not.
    Noticed the gap between the rear pod and the body has increase by 15mm at the top from bottom. Unsure how accurately it was set up in the beginning, its mounted on a corrugated rubber so perhaps some compression taking place? I dont think there is that much weight in the pod in all honesty. I will have to crawl around and have a look at the chassis, but its already plated inside and out. From a mechanical/structural perspective the chassis plating systems dont do much to bending resistance, more reduce chassis box section stress. I may design up some deeper section profiles and get them cut, ie increase the section depth of the rear chassis rails by say 40mm+ using 8mm plat - will run some numbers to see what the reduction in bending is, will help. Its a mission of a task to execute though - but just time and money.
  2. The Following 3 Users Say Thank You to PeeBee For This Useful Post:
    mudnut (5th January 2026), poindexter (6th January 2026), Touses (6th January 2026)
  3. #832
    Started on the drivers side rear chassis stiffener plate. Its 200 x 6, welded to the outside of the chassis rail via dia 50mm hole saw holes, at both ends and stitched along the top. I will stitch the inside plate in the near future to the chassis rail. The weld zone turned out a mess! The mig welds were beautiful, then I got it into my fat head to fill up the centre 'donuts' with body sealer/deadener to fill up the depression - well you can see the result. I think I will let this dry then smooth it off with a top coat, will come up fine. Was speaking with @MB this arvo and whilst the plate extends to the rear side of the trailing arm pivot bracket, he suggested I try to extend further forward. Its a good thought, however there is only 50mm from the top of the chassis rail to the floor, and its congested and busy, so have to think that thru a bit. Hs thoughts are based around the GQ ute has 4 tray mounts, two are in front of the trailing arm bracket and two to the rear. You can see the first POD mount I have which is just behind the chassis bend and the second about 200mm from the rear of the chassis. I am already plated out inside and out in the region, so will think about this further. I am still not at root cause for the 15mm drop of the POD at the rear, will find it in time no doubt.
    Passenger side is next, takes about 6 hours start to finish per side.2026-01-17_181218.jpg
  4. The Following 3 Users Say Thank You to PeeBee For This Useful Post:
    Cremulator (18th January 2026), mudnut (17th January 2026), Touses (18th January 2026)
  5. #833
    Passenger side stiffener plate fabricated and installed, slightly shorter due to the cross bar mount, finished it off with the body deadener, yeah came up the same as previous, more cosmetic work to do. Planning the POD packer task for after my return from site. My neighbor gifted me a slide out drawer cartridge with the fold over tray for a BBQ, looking to swap that over for the slide drawer I have in place now.
    About to pull the pin on a Bushwacker 180 Deg Awning, on special 50% off, cant lose I reckon, good strong pivot arms, but dont carry the same integrity impression of the Bush Company unit that comes from South Africa, specifically designed without poles as rated for the wind - to a degree. Did a measure up for the 270, but the supports are difficult to allow for the rear 90 deg cover, so the straight down the side protection is the go. Will wait for them t come on sale I think as still expensive for what they are.
  6. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    mudnut (4th February 2026), Touses (5th February 2026)
  7. #834
    This mornings post disappeared, so here is the second pass. I raised the rear of the canopy by 12mm on the rear mount, 6mm on the centre and its essentially 'spirit level flat'. Took about 6 hrs start to finish, rear storage boxes had to come off, myriad of bee stings, but its done.
    Also installed a different drawer system in the POD, that actually looks like it should be there, not an engineers solution of form follow function. Rear Pod drawers.jpg
  8. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    Cremulator (19th February 2026), Touses (19th February 2026)
  9. #835
    OK, reliability testing continues. The little green plastic knob battery post isolator, brass on brass decided to shit itself on the way back from the High Country on friday, finally fell apart 500m from home at the traffic lights, stopped the car dead ( threaded knob stripped out the internal thread in the post block). It was hot, I was tired, didn't end well. Anyway, I got going in maybe 3 minutes but not without a lot of aggro from drivers who had to use their steering wheel to drive around me. Have now changed the device to a rotary marine isolator - Narva style, s should resolve that.
    Lost the AC again - ground wire broke off at the earth terminal - small but very effective way to kill the interchiller operation, 15 minutes to find that one.
    Set up the new awning and left it in a horizontal plane instead of a corner dip to shed water, got hit with a massive downpour just after setting it up - within minutes, and the center filled up and bent one of the side poles - rookie mistake, went to Tentworld when home and got a replacement internal pole, sorted.
    The Icom IC400 remote speaker jack to pin decided to increase its clearance so was able to transmit but not receive via the external speaker. That took 4 hrs to resolve once home, now using the local facia speaker instead of the remote - will see how that goes. I think the issue is the 2.5mm jack is a right angle and it does not sit that well with the rear case of the radio. A straight out fitting would work better - will chase from Jaycar for an adapter.
    Apart from these beestings, running well, no smoke or fires, batteries and inverter set up working well, recharged the batteries for the chainsaw maybe 10 times, fridge freezer good, happy days, might be on the pathway to reliability, finally.
  10. The Following 3 Users Say Thank You to PeeBee For This Useful Post:
    BrazilianY60 (1st May 2026), Cremulator (2nd March 2026), jff45 (2nd March 2026)
  11. #836
    Went chasing two electrical gremlins. The first was no power within the horn circuit. I wanted to add a small but loud air horn to supplement the pipsqueak pip, and then could not get it to work. 4 hrs later, turned out to be corrosion on the prongs of the horn relay, relay was cycling but too much resistance. Anyway, I pulled the sub assy apart, contact cleaner applied, problem fixed.
    Next the a/c circuit would not engage the compressor clutch, again, the actual relay had failed across the power circuit, so a new relay sorted that out. Took an hour to find that one amongst the rats nest of my 'improved' wiring loom.
    Now the last headache is trying to get the after market cruise control working, I must have something stupid cocked up as its a pretty basic set up, but cant even get the actuator to cycle under a test mode - more hours of pain coming down the way I assume.
  12. The Following 4 Users Say Thank You to PeeBee For This Useful Post:
    Cremulator (17th March 2026), mudnut (16th March 2026), pearcey (17th March 2026), Touses (9th April 2026)
  13. #837
    Bit of a frustrating day Sunday. Recalling my major fuel contamination issue, I disconnected the flowmeters from the fuel system to isolate the problem, then left them open ported to the atmosphere - bit mistake it now turns out. I decided to re-install them on Sunday and it was a messy job, another ill thought thru location when the body was off - not that serviceable without getting a bath in diesel trying to break overhead diesel lines. Anyway, job was done, everything primed up well with the lift pump, sat there idling in the driveway for 10 mniutes, then coughed and spluttered and stopped. I checked the usual suspects and reverted to the 'what changed' ab\nd then back under the car and disconnected the 4 hrs of work to take the meters out of play. I did it one at a time to see if I could isolate the particular culprit, so think I know which one has failed. Primed via the lift pump again, fired up with a splutter and all good. Started the hunt for replacement units, Ordered a couple off the internet - cheap units, and also made contact with two other Melb based supplier of turnkey solution - noth in the order of $1500 - again, expensive mistake as in reality the flow meters were never the problem. I am going to try and remove them for inspection/repair however they are bolted from the top, thru the rear cross spring tower brace, and super tight clearance - another oversight.
    Whilst under the car I noticed the spring coil to shocker clearance was very small - just about touching, so adjusted the rear arms that roll the diff forward and achieved 20mm clearance - could be a little more but pinion angle now flatter and clearance restored, happy for now.
    Finally waiting on some 15mm coil spacers for the rear to trim the minute rear droop. I played with going back to airbags but not worth the cost V prize, plus they are a PIA to install.
    Thats it for now, back to work again, still from home and seems like this war could reduce my site travel a bit and affect project executions, will see.
  14. The Following 3 Users Say Thank You to PeeBee For This Useful Post:
    Cremulator (24th March 2026), mudnut (24th March 2026), Touses (9th April 2026)
  15. #838
    Took a bit of quiet time yesterday to concentrate on the replacement AP60 Cruise control system I installed after munching the original up with a shredded belt. I have not been able to get it to operate.
    Anyway, I back tracked thru the wiring and found I had the brake signal wires connected to the clutch disconnect switch, so removed that, and then spent the next hour trying to find a way to get a signal off the circuit. (There is a circuit to run that links both the clutch disconnect switch to the brake disconnect - its just that somehow the controller is able to distinguish between the two switches as it does not even work without the brake disconnect being in the circuit)
    The wiring loom pigtail is short when disconnected from the brake pedal so I tried a couple of crazy jumper pigtails however the unit continues go into fault mode, specifically on the brake switch circuit. Its too tight that even an octopus could not reach the cables, so I bought one of the Tee Scotch lock sets last night and will see how that goes - its the type where the lock is crimped on the wire and the jacking wire comes off at right angles.
    Re ran the actual actuator cable also to get it as 'long radius' as possible, so when I get a minute will see if I can resolve this first hurdle. Bloody hell this conversion has been so long n the tooth, will be glad if it ever ends!
  16. The Following 3 Users Say Thank You to PeeBee For This Useful Post:
    Cremulator (31st March 2026), mudski (31st March 2026), Touses (9th April 2026)
  17. #839
    Expert Brissieboy's Avatar
    Jul 2015
    Brisbane, Qld
    10 Post(s)
    Considered mounting a separate switch to operate off the brake pedal just for the cruise? Plenty of suitable microswitches available so just need to mock up a suitable mount.
  18. #840
    Good point, it may get to that situation. What I cant fathom is the specific fault generated by the controller aligned with the brake switch only connection - perhaps my rickety spade connections were not tight enough or faulting? Anyway, the first attempt failed so I will try the scotch lock assy then if that fails I can rig up a parallel switch for sure. The existing switch does need power to it but not a biggie, thanks for the reply also, does help getting external clarity.
