Results 1 to 3 of 3
Thread: TD42 Temperature Issues…
    Aug 2025
    Confused and need some ideas on what to check. For context I drive an 07 TD42T swapped GU.
    Situation is I was driving from Sydney down south on the Hume Hwy and noticed that about 2 hours in the coolant temp kept dropping on my redarc gauge to around 68-70*C at 110kmh and would peak about 83*C on hills - normally runs around 80*C peaking at 90-95*C on hills - was normal for the first 2 hours.
    It’s been a cold and rainy few days and in the morning the temperature refuses to rise even after 10-15mins idle it was sitting at max 30*C until I start driving.
    Today (18*C) on my lunch break I let the car idle after driving back to work and the temp kept rising and rising until I switched it off around 95*C to go back to work.
    I assumed I had a faulty thermostat so have ordered a genuine 82*C thermostat and plan to replace and do a coolant flush this weekend. But now I’m confused as if the thermostat was stuck open why would it rise so much at idle today?
    So 2questions:
    Any harm in driving it back to Sydney on Friday - what temps are too cold and too hot for a td42t running 14psi
    And
    Any other ideas about what’s going on
    84 Post(s)
    Failed units do strange stuff.
  3. The Following User Says Thank You to mudnut For This Useful Post:
    geoffayres (6th November 2025)
    Feb 2012
    I had a thermostat go dodgey on me. It was a near new unit, Nissan boxed.
    Temps were all over the shop, with no logic to it at all.
    Replaced it, and all good since...
