Results 1 to 4 of 4
Thread: Td42 with td42T automatic transmission
    Jul 2016
    Hey guys and girls
    I am after some advice I’m sure someone has done this before I have a 1991 Nissan Safari GQ with a TD42 nonturbo engine ,I am trying to put a 1994 Nissan Safari GQ TD42T automatic transmission in but the flex plate will not bolt to the torque converter as the bolt are spaced more further apart. Is there a flex plate of another vehicle that I could possibly use, I have heard of the ZD30 flex plate but would like someone with a bit more knowledge to comment on this.
    Thanks a lot everyone any information would be very much appreciated
    THis could be a question to Patrol a Part? They will know instantly and be able to supply what you need. Drop them a line - good company to deal with.
    Jul 2016
    I gave them a message we will see what they say but if anyone else knows on here that would be also very great
  4. The Following User Says Thank You to d1rty30det For This Useful Post:
    PeeBee (26th October 2025)
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    13 Post(s)
    Look up Magnum flexplates. They do a heavy duty item for the T engine with the bigger PCD.
    Edit: Should have written that Magnum can make a standard flexplate for the non-T engine which is what you're after.
    Don't use a ZD30 flexplate, they break already with the ZD30 engine.
    John
  6. The Following 2 Users Say Thank You to jff45 For This Useful Post:
    PeeBee (27th October 2025), Touses (27th October 2025)
