Results 1 to 10 of 14
Thread: 2025 Patrol Warrior Rear Recovery Points
    Feb 2018
    Hi.
    Just picked up my new warrior patrol, getting ready for a trip.Does anybody know what D shackles fit the warrior rear recovery points.
    None of my existing one's fit.The holes look very small.
    Thanks for any assistance.
    Tony
    SUCH IS LIFE Maxhead's Avatar
    ACT
    I think everyone is using soft shackles mate. Might be time to change
    ________________________
    ______ 2017 D-Max _______
    Feb 2018
    cheers.No drama in changing my existing soft shackle won't fit thru the rather small holes.
    Expert Brissieboy's Avatar
    Jul 2015
    Brisbane, Qld
    10 Post(s)
    If a D shackle and your soft shackle will not fit through the hole, I question whether the point you are using is a true recovery point. I would be VERY careful here.
  5. The Following 2 Users Say Thank You to Brissieboy For This Useful Post:
    mudnut (14th October 2025), mudski (15th October 2025)
    178 Post(s)
    Quote Originally Posted by Brissieboy View Post
    I was thinking the same. How many cars actually come fitted with recovery points? Sounds more like tie down points?
    Feb 2018
    Thanks. But they are definitely recovery points as advertised by Premcar. In the promotional material.Apparently I am not the only one struggling to find a shackle that fits.On the Facebook Warrior group someone suggests Matrax Fuse soft shackle fits.Thay are a 10mm diameter might get one and try.
    Feb 2012
    What is the diameter of the hole in the recovery point?
    Jul 2015
    Brisbane, Qld
    10 Post(s)
    Quote Originally Posted by tonyci View Post
    Do not believe everything in the promo material - believe it or not advertising blurb has been known to stretch the truth a tad. Have a real good look at the alleged 'recovery point'. Is it welded or one piece? What thickness material is used? To what is it attached? How is it attached? Is there a certification of any sort anywhere? Is there some rating provided? Has it got smooth edges in the hole that will not damage a soft shackle? Is it simply a 'tow' or 'tie-down' point?
    Maybe show us where it is claimed to be a 'recovery point' and/or show us some detailed photos.
  10. #9
    Feb 2018
    Away from the car currently. They are definitely recovery points.
    TWO 3,500KG§ RECOVERY POINTS
    The revised towbar setup features two rear
    recovery points to help get you – or more likely,
    your mates – out of tough spots.
    Copied from the car website
  11. #10
    Can you link to the website so we are seeing what you are. And a photo would be handy.
    Edit : Just found the Premcar website, I'd be very careful using those. The rear points looks rather small going by the website picture. Which is small also.
    For the fronts i'd go these.
    https://patrolapart.com.au/product/r...atrol-y62-pair
    Not sure if there is aftermarket rear points for sale, i've never looked. But I'd be looking into those if they are available.
