Results 1 to 6 of 6
Thread: TD42 Blowen Heagasket
    Sep 2025
    Hi everyone, has anyone had other issues with a blowen headgasket on TD42, mine appears to have stuffed the piston rings also, just wondering if anyone else has had this problem, cheers Paul s
    477 Post(s)
    Id say those two things might not be related. I can't see how a blown head gasket would stuff the piston rings. Unless the gasket allowed coolant into the cylinder when then this stuffed the rings....But im no mechanic.
  3. The Following User Says Thank You to mudski For This Useful Post:
    Paul s (23rd September 2025)
    Sep 2025
    I thanks for your reply, motors been very hot it had 7 thou warp no cracks, I've had the head machined valves lapped, new head gasket new headbolts, rocker clearances set to 14 thou, very hard to start now runs very rough, lots of smoke, and seems to be pressurizing the oil, compression tested, and all cylinders well down best 150 psi, all others below 100 psi, don't see any other choice but to remove the head and remove the pistons? cheers paul
    84 Post(s)
    Get an oil can with a long flexible hose and small nozzle. Do a compression test. Remove the test gauge and squirt a smidgen of engine oil into the cylinder.(Not more than a spoonful of oil as you don't want to hydrolock the engine) Turn over the engine a few times to spread the oil.
    Now do another compression check. If the reading significantly increases, then it indicates worn rings.
  6. The Following 2 Users Say Thank You to mudnut For This Useful Post:
    Maxhead (19th September 2025), Paul s (23rd September 2025)
    477 Post(s)
    Quote Originally Posted by Paul s View Post
    Theres your answer. low compression will tend to pressurise the sump
  9. #6
    Sep 2025
    Yeah I’ve seen a couple do that, usually when they’ve been pushed hard while already running hot. Did you get any signs before it went (smoke, loss of compression, coolant loss etc.)?
