Results 1 to 5 of 5
Thread: Type Pressure
    Aug 2025
    Perth
    Type Pressure
    Hi Everybody
    I'm new and would like to know what type pressure should you be running in 275/70R17 ?
  2. The Following User Says Thank You to Shane1972 For This Useful Post:
    BigRAWesty (24th August 2025)
    Quote Originally Posted by Shane1972 View Post
    Hi Everybody
    38psi is always a good number for bitumen.
    Aug 2025
    Perth
    Quote Originally Posted by BigRAWesty View Post
    Thank you
    198 Post(s)
    Another consideration is load. My GQ is heavy and for road travel, Melb to the Madigan I was running at 60 psi on the HD Terrains as their load rating is right up to 85psi for max. Trouble running so hard is the tire heat up on the road and I quickly found I was deflating them in the heat. So ambient temps and types of driving are important.
    When we got into the sand and soft corrugations I dropped to circa 35psi when the other vehicles were at 20psi. If I dropped to 20 I would be running on the rims! I had adequate floatation at those pressures.
    84 Post(s)
    I run the Ol' Trol at 28-30 psi. It is basically stock weight except the winch. I pump the tyres up to 35-38 when towing the caravan. If I don't run the lower pressure the vehicle wants to shake itself to bits on the unvehicle-worthy pot holed pieces of crap we call highways, here in S.W.Vic.
  7. The Following 2 Users Say Thank You to mudnut For This Useful Post:
    BrazilianY60 (28th August 2025), PeeBee (27th August 2025)
