Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Failed ARB shocker??
    Yea, Victoria
    Took my GU out for a very short drive yesterday..... Very short because the car was un-drivable. At about 60-70 KPH the steering wheel wanted to shudder out of my hands. I had a look around the front end today. The only thing I could see was the gas reserve on the drivers side ARB shocker lookds to be leaking... I have attached a pic of the suspect one and the other side for comparison. Whats the general thought on this. Could this be the problem??
    84 Post(s)
    Don't like the look of that weeping. Rock that side of the Patrol as violently as possible. If the body stabilises within 1-2 bounces the shocker should be still good. The only other way is to undo the shock and see how easily to moves using as much force as you can manage. It should resist any input you give it. The signs that you described sounds like the start of the dreaded death wobbles.
  3. The Following User Says Thank You to mudnut For This Useful Post:
    PeeBee (26th January 2025)
    I agree, its not the source of your problem, look at your bushes - all of them. Normal Nissan patrol issue.
    Patrol Freak Touses's Avatar
    Mar 2016
    Childers QLD
    22 Post(s)
    The dreaded death wobbles!!!!
    Where to start?
    A shit shocker is unlikely to cause wobbles, it could well exacerbate same,
    Seriously, start with wheel bearings and draglink.
    Go from there, has always been my major probs although GQ not GU.
  6. The Following User Says Thank You to Touses For This Useful Post:
    What rims are you running CC? If it’s stock GU steelies, start with the basics of the basics first. Those rims love to harbour mud/crud in the 1” groove behind the “spokes”.
    (Not GU rim here, but for reference).
    Gong him Red!!
  8. The Following User Says Thank You to Plasnart For This Useful Post:
  9. #6
    Yea, Victoria
    When I first got this it was after being parked for about two weeks. The last time I drove it it was perfect. It could be that the shocker leaked over the two weeks of being parked. All my front end bushing have been replaced about 6 months ago and my front wheel bearings have been replaced about two years ago. There was no build up. It just violently started shaking when I got to about 60kph....
  10. #7
    What make and ply rating/load rating are your tires? Sitting for 2 weeks may have egg shaped them a little that would work its way out over time I understand. the 60kmhr point may just be rotten luck with all tires cycling at the same time as out of round. Do a check on the web for known out of balance issue with the brand . My cross plies were a bastard for this, and even a set of Kumho Mud Terrains would act up for the first 20klm before settling down.
    mudnut (27th January 2025)
  12. #8
    84 Post(s)
    Yep, had a set BFG rugged terrains that would do that when cold, after sitting for a while. Eventually replaced the worn out steering damper and that made the shakes barely noticeable until they disappeared around five or ten ks, depending on the temperature.
  13. #9
    Yea, Victoria
    Sent the photo to ARB. They just called and said that they would replace the shocker under warranty. It should not have happened given the cost of these things but at least they are standing by their product.
  14. The Following 2 Users Say Thank You to Coldcomfort For This Useful Post:
    mudnut (28th January 2025), PeeBee (28th January 2025)
  15. #10
    177 Post(s)
    ARB have been great with a few items I've had to "Warranty" over the years. I'm not surprised they're replacing that for you. However the shocker is NOT your issue considering your symptoms.
    Check your tyres mate.
    A few years ago, my Patrol had what you describe AND more. Car just felt rough, noisy at various spots on the speedo. And it progressively got worse as time went on. But I had no wobbles. And still doesn't, thank f$%k!
    It drove me insane. I checked bearings, bushes, etc... Later on bearings were replaced as well, and still fixed nothing.
    Can't remember why, but I rotated the tyres and BINGO!! I had the same issue but was now more to the rear of the car. That's where I clicked, front left went to rear right during rotation.
    I took the suspect tyre off and slapped on the spare and Patrol drove like a dream!!
    I'm only assuming that tyre had belt separation.
  16. The Following User Says Thank You to Hodge For This Useful Post:
