Results 1 to 5 of 5
Thread: My first Patrol-G60
    Beginner locky's Avatar
    May 2016
    Leopold, Victoria
    My first Patrol-G60
    My first was a G60 SWB purchased in 1984
    It evolved over the next few years. Initially I put on 10.5x32x 15 Mud Terrains, shortly followed by a 400ci Small block Chev mated up to the 3 speed crunchy box. The engine was balanced had double hump fuely heads, 10.7:1 compression, torquer 2 manifold, many different carbys (looking for something that ran on angles), custom extractors and intake. I can't remember the cam but idled kinda OK and made close to 400hp on the dyno. A bit later 33 inch Samyang MT. Yep; at around 86 inch wheel base it was a handful without power steering and real brakes etc. After several breakages we adapted a 9" front diff into it using 30 spline Toyota axles and disk brakes. The rear diff never broke and proved quite tough, although the rear prop shaft broke a couple of times.
    Since then we adapted a ford top loader 4 speed and after that a turbo 400 auto, 35 inch Mud terrains. The Black and white image was taken by the local paper back in the day. I believe it was at Forrest Frolics an event that was once run by the Geelong 4X4 club.
    Fun Times
  2. The Following 5 Users Say Thank You to locky For This Useful Post:
    AB (10th January 2025), BrazilianY60 (9th January 2025), mudnut (9th May 2025), Plasnart (8th January 2025), Touses (8th January 2025)
    Nov 2019
    Perth
    5 Post(s)
    Looks good! Where is it now?
    2008 CRD Auto Wagon
    May 2016
    Leopold, Victoria
    I wish I knew!
    Unfortunately I sold it in the late 80s
    May 2025
    Looks good! , what a lovely car , too bad that you sold it
    May 2025
    that looks sick, id love one like that
