Results 1 to 4 of 4
Thread: OBD2 with more capability...
    Yea, Victoria
    https://www.azscanners.com.au/icarso...ota-mazda-mits
    Does anyone have any experience with these. It can re-trim injectors apparently.....
    Beginner locky's Avatar
    May 2016
    Leopold, Victoria
    This is quite interesting! Could anyone recommend a scanner with good functionality at a reasonable price. That says Japanese only, isn't OBD2 a standard?
    Nov 2019
    Perth
    5 Post(s)
    I use the cheapo one from 4wdsupacentre, it's very limited. If I was recommending I'd say "spend more and get one with more sensor readouts" such as a scanguage 2/3
    2008 CRD Auto Wagon
    Jul 2018
    It also depends on what ability the car has to be tuned via OBD. Just because it has an OBD connection, it doesn't mean it can be used for everything. I just use OBD link and I can access everything that is available via an ipad along with any fault codes and clearing of fault codes .. I can have all the systems up in a split screen on the ipad and also navigation maps at the same time. I can also see real time temperature rather than fitting a gauge :-)
