Page 569 of 570 FirstFirst ... 567568569570 LastLast
Results 5,681 to 5,690 of 5698
  1. #5681
    Quote Originally Posted by Brissieboy View Post
    Somebody want to explain what these are actually for? Having a bit of trouble trying to figure out how and where they migh be of so much benefit.
    So the first bit on the left is an adaptor so it can fit over the Nissan bottle jack, piston head, I suppose you call it. The middle bit is just an extension piece, which fits over the first bit, so the vehicle can be lifted higher that what the jack can.The third bit, on the right fits on either the left of middle bit, or both together if needed, and goes under your axle when jacking up.
    Hope this makes sense.
    These are handy so you can use the OEM bottle jack when you have bigger tyres.
  2. The Following 2 Users Say Thank You to mudski For This Useful Post:
    Brissieboy (2nd November 2024), Hodge (1st November 2024)
  3. #5682
    I was heading out for a quick fishing trip to the favourite 'Burgoynes Gap' locale and needed to replace a squealing belt - called upon Mark @mudski and he responded in brilliant fashion as normal, arranged so i could pick up the belts at the supplier, and had them fitted the same morning. Brilliant help, took the background high rev squeal away, once again amazing co-operation, encourage all members with any automotive parts requirements to reach out to him.
  4. The Following 5 Users Say Thank You to PeeBee For This Useful Post:
    Hodge (1st November 2024), mudski (1st November 2024), Plasnart (1st November 2024), Stropp (2nd November 2024), Touses (1st November 2024)
  5. #5683
    177 Post(s)
    @mudski is a legend
    I've been getting bits and bobs through him when he had the parts shop. And for many years now the servicing kits AND the Green belts. Top of the line.
  6. The Following 2 Users Say Thank You to Hodge For This Useful Post:
    BrazilianY60 (1st November 2024), PeeBee (1st November 2024)
  7. #5684
    Expert Brissieboy's Avatar
    Jul 2015
    Brisbane, Qld
    10 Post(s)
    OK thanks, that does make sense. I just use a block or similar under the jack. I carry a small slab of 3/4" formply to form a decent base and can even build up under that with dirt or bits of saplings etc - do what ever is needed at the time. But almost 200k km and I have never had to use the jack, at least on my own vehicle.
  8. #5685
    Finally got the rear bar on, bonus is that it doubles up as a great bar..
  9. The Following 4 Users Say Thank You to jay see For This Useful Post:
    mudski (4th November 2024), PeeBee (2nd November 2024), Stropp (2nd November 2024), Touses (3rd November 2024)
  10. #5686
    Nov 2024
    A fuck cancer sticker for the back window
  11. #5687
    I went thru the selection process today with Dobinsons for a new set of rear coils. I am sitting 12-15mm down at the rear with empty tanks and unloaded, and want to get rid of the airbags. I gave them the loads on front and rear and the preferred lift above standard - 50mm, and it spat out a couple of options right up to military rated coils - very impressive. I have decided to go with a set of 250-400kg variable coils with 100mm lift, should result in a lift of 30mm above what i have now and the truck will sit nice and unremarkable to PLOD. They are C45-315T coils, 22mm dia wire, pick up monday.
  12. #5688
    Good to hear someone else espousing properly rated coils over chucking in airbags. Your chassis will thank you.
    Let tougher variable-rate springs do their thing via that torsion effect.
    Don’t transfer direct load to the chassis through air bag-stiffened springs.
    Won’t see your chassis broken in half down the track.
    Install spring tower braces too as best practice.
    Happy travels.
    Gong him Red!!
  13. The Following User Says Thank You to Plasnart For This Useful Post:
    PeeBee (22nd November 2024)
  14. #5689
    Apr 2021
    Brazil
    Didn't buy anything unfortunately but saw this add on Gumtree, maybe it is something someone is looking after:
    Brand new ARB GQ bulbar. Its listed as clearance item, not sure how much it would cost new.
    https://www.gumtree.com.au/s-ad/kang...ick/1328710632
  15. The Following User Says Thank You to BrazilianY60 For This Useful Post:
    mudski (1st May 2025)
  16. #5690
    Wow how generous. Clearance sale, RRP $1890 now slashed to $1800. Crazy bargain!
    Gong him Red!!
  17. The Following 5 Users Say Thank You to Plasnart For This Useful Post:
    BigRAWesty (9th June 2025), BrazilianY60 (10th June 2025), mudnut (10th June 2025), MudRunnerTD (10th June 2025), PeeBee (1st May 2025)
