Results 1 to 4 of 4
Thread: TB42 EFI - Runs rough and backfires
    Jul 2024
    My TB42 runs only on petrol. Suddenly, the engine started to cut off and now it's running rough and backfiring. I have already attempted the following repairs for the issue, but there has been no improvement:
    - Changed the coil
    - Replaced the distributor cap and leads
    - Installed new spark plugs
    - Replaced the oil filter
    - Had the injectors professionally serviced and tested
    Any suggestions would be greatly appreciated.lp
    Patrol Freak Touses's Avatar
    Mar 2016
    Childers QLD
    22 Post(s)
    I'm no expert on petrol donks. My train of thought is leading to a timing issue.
    Expert Arfa Brayne's Avatar
    Jul 2016
    You need to check the pressure in the fuel rail.
    If the pump is not supplying enough pressure and flow, you'll get rough running and backfire.
    Does your Troll run clean if you floor the accelerator? - (ECU full fuel bypass)
  4. The Following 2 Users Say Thank You to Arfa Brayne For This Useful Post:
    mudnut (15th July 2024), Stevo95 (17th September 2025)
    May 2025
    Southern nsw
    Arfa love that saying
