Results 1 to 10 of 16
Thread: Load rating 126 all terrain recommendation
    I picked up another set of the GU factory 17" alloys so I could fit them out with a set of all terrains. . 4 of the tires are shagged, but the 5th is a brand spanking BFG Mud terrain KM2, never been on the road - made the $250 purchase price even more attractive.
    The Kumho's (i run these now) are load and speed rated at 122/118R, however I want a higher load rating for longer duration touring, something around the 126 rating, but can only find a BFG All terrain listed, circa $550 - $600 a corner. I am not concerned about the cost, more the construction and load rating.
    Does anyone have any recommendations? Tire size i am looking for is 285/70/17 LT construction
    https://www.bobjane.com.au/a/285-70r...riant_id=39132
    Can purchase as low as $500 a corner it seems
    https://www.ozzytyres.com.au/tyres/a...285-70r17-126q
    Ok, two threads evaporated tonight, again. Am I to assume it's a system issue when the 10yr trip remains in play or a MOD deciding the posts are not worth the content, simple honest answer will be appreciated. Happy to go silent like a large number of members if that the message.
    I would be astounded if you’re getting modded PB. In fact it’s almost incomprehensible that would be true. The forum is pretty clunky at the moment.
    Anyway, I think you’re over-engineering with a 126 load rating mate. That’s friggin high at 1700kg from a quick Bob Jane lookup.
    I always ran Mickey Thompson MTZs on my GU tourer (at 305/70/16) and they are only 121 rated at 1450kg.
    I wouldn’t stress. If you’ve got LT with 3-ply sidewalls and a reputable brand I’d be comfortable.
    My only avoidance would be tyres sharing a name with a great SA brewery. Wouldn’t go there based on past delaminating problems.
    Gong him Red!!
  4. The Following 2 Users Say Thank You to Plasnart For This Useful Post:
    PeeBee (7th July 2024), Rossco (7th July 2024)
    Yeah see your point. I need to put the car over the scales I bought I guess. I am thinking about heavy loads and lower pressures which greatly de-rate the tire - if you look at the ratings they are all at 50psi cold.Will dig a bit deeper.
    I have reached out to BFG and Kumho for comments on running tires at say 20-25psi for extended periods in 30degC temps at low speed - will see what they come back with. Coopers publish a 6psi reduction reduces load rating by 20%. This is due to increased temps from wall flex. I am sure there is adequate tolerance in the 121's but just need to see if anyone has any facts around this they have found.
  7. The Following 3 Users Say Thank You to PeeBee For This Useful Post:
    BrazilianY60 (8th July 2024), mudnut (7th July 2024), Plasnart (7th July 2024)
    I don’t have any scientific calculations, academic assessments or technical specifications to provide you Phil, but my anecdotal evidence indicates you should be fine. After many outback kilometres, generally at 18psi on unsealed tracks and sometimes no tracks at all, traversing sand country, mallee country, spinifex country, limestone country, hard corrugated country, deep bulldust country and boghole country, I not once experienced a flat Mickey Thompson MTZ.
    There was one place I did tear the side wall out though. That was exiting the Ouyen BP servo and was flat by the time I crossed the road. And I couldn’t find the culprit. Go figure!!!
    Gong him Red!!
  9. The Following User Says Thank You to Plasnart For This Useful Post:
    PeeBee (9th July 2024)
  10. #7
    Its a point to consider. I did destroy a perfectly good heavy duty cross ply tire running it too low, when the tire was pulled off the rim to replace the inside was a mess of delaminated chords and shredded rubber. I know the construction is different with radials, however having repaired hundred of flat and damaged tires as teenager in a garage, the radials come apart as well. I know even my run flats on the BMW stripped apart at run flat pressures - tire wall flex is a killer.
    I have not heard back from either company, so will chase today between oxygen free meetings.
  11. #8
    Chased both companies and 'no idea' is the resounding echo. Waiting for some info to come back, 'whenever' they have it. I am amazed this isnt as easy an answer to resolve.
  12. #9
    OK, Kumho can not advise load rating at 20 psi, as the tire is rated at 80psi for max load capacity. Just slow down below 30psi.
    BFG, not the slightest idea, sorry cant help.
    Brilliant outcome.
    mudnut (9th July 2024)
  14. #10
    Further to the positive response from BFG/Michelin, I decided to approach the head office in the USA for an answer as the Australian office clearly could not be stuffed answering or even researching the issue, only to receive a cordial response from them to say, speak to the local office. There is another brand with a 126 rating 'Sailen Terramax TR AT71 Rugged, but only 2 tires in the country at the moment, unsure if further units coming into the country - the chase continues. These are manufactured in China, however looking at side wall construction as well as reduced pressure rating.
