Page 1056 of 1057 FirstFirst ... 1054105510561057 LastLast
Results 10,551 to 10,560 of 10564
  1. #10551
    Hold steady on purchasing Team NP
    Its first two Dyno runs today kept blowing the hose off at the W2A Intercooler outlet side
    Have raced across to Lilydale with two (2) of my original setup Norma T bolt style clamps that handled its first Dyno 2,000km ago.
    I used these on the GUIV running 28PSI and never had a problem with them
    https://www.uniclamp.com.au/products...29c99014&_ss=r
  2. #10552
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    40 Post(s)
    Been finishing off installing some gauges and bits in the top flap of center console GUIV, but out in came again to change e-locker switch... it gets easier
  3. The Following 2 Users Say Thank You to Bidja For This Useful Post:
    10G (18th June 2024), PeeBee (18th June 2024)
  4. #10553
    May 2016
    lower west victoria
    30 Post(s)
    Hey, that's woken my brain up. How hard is it to remove the stock radio? I might be doing that soon.
  5. #10554
    Jul 2017
    40 Post(s)
    Will be putting it back together today, I will take some pics to show.
    Only a couple of screw in the console to remove and then pull it towards u from top (removed).
    Then 4 screws holding radio in place.
    Always harder the first time.
  6. #10555
    476 Post(s)
    Wait until you need to do a full dash removal for a new heater core. Done mine twice now, one for the heater core then the A/C evap went. Not a hard job, just time consuming.
  7. #10556
    Jul 2017
    40 Post(s)
    Remember seeing the pics (a pre trip job).
    I started with just removing the tunnel full console to re-fix the gear shift boot and remove 16yrs of dog hair (fond memories of best mates).
  8. The Following User Says Thank You to Bidja For This Useful Post:
    mudski (19th June 2024)
  9. #10557
    Jul 2017
    40 Post(s)
    Cluster all hooked up and even works. haha
    Main and Aux battery V_meters w/2xUSB chg ports each.
    Auber type gauges w/pyro measuring air temps in hot/cold side FM cooler.
    Switch E-locker + a secondary isolator rocker around side of console.
  10. The Following 3 Users Say Thank You to Bidja For This Useful Post:
    BigRAWesty (18th June 2024), BrazilianY60 (19th June 2024), Cremulator (18th June 2024)
  11. #10558
    Finished wiring in all the lights.
    I think I have enough..
  12. The Following 5 Users Say Thank You to BigRAWesty For This Useful Post:
    Bidja (19th June 2024), BrazilianY60 (19th June 2024), Cremulator (18th June 2024), mudski (19th June 2024), Plasnart (18th June 2024)
  13. #10559
    Jul 2017
    40 Post(s)
    Check this post out may help mate:
    https://www.nissanpatrol.com.au/foru...418#post846418
  14. #10560
    Feb 2014
    Southern Tasmania
    New (used) non-leaking vacuum pump 110 amp altenator installed.
    Also upgraded the wiring to the battery with 185 amp rated wire that has a 125amp midi fuse on the battery and one for the altenator side. Basically ripped off the idea from the Qikazz website and made it myself for a lot less with some stuff I had laying around.
    Even got fancy with nutserts instead of tek screws.
    You can see the turbo is off while I was waiting for a turbo to dump pipe gasket from MTQ to arrive.
  15. The Following 3 Users Say Thank You to gazq For This Useful Post:
    10G (20th August 2024), BrazilianY60 (20th August 2024), Touses (20th August 2024)
