Results 1 to 10 of 18
Thread: 3rd row seat bolts
    Jul 2018
    3rd row seat bolts
    Hi all, does anybody know what the 3rd row seat bolt threads are? The ones that go into the wheel arch.
    Jun 2018
    25 Post(s)
    On my GU III they are M10 1.25
  3. The Following User Says Thank You to Cremulator For This Useful Post:
    BigRAWesty (7th June 2024)
    Nov 2019
    Perth
    5 Post(s)
    They're steel
    2008 CRD Auto Wagon
    Expert Brissieboy's Avatar
    Jul 2015
    Brisbane, Qld
    10 Post(s)
    Yep, definitely M10 x 1.25 pitch on my 2015 GU wagon.
    Jul 2018
    Nope not M10 1.25 pitch. Mine are a fine thread.
    Quote Originally Posted by timbo2410 View Post
    If its not 10 x 1.25 then it will be 10 x 1.0, standard is 10 x 1.5
    Jul 2018
    Thanks for that :-)
    Thanks for that :-)
    Do you have a tap you can run thru the holes? The seat belt bolts to nots seem quite a precise fit for obvious reasons I guess. I typically find the right thread then run the appropriate tapping tool through to clean the threads up as they are usually a bit corroded and also it does not take much to bet them splayed a bit and tight to get in. Also use a smidge of anti seize or even straight oil, makes a big difference and wont negatively affect the load rating.
  10. #9
    Jun 2018
    25 Post(s)
    This is the factory bolt from my rear seats with a 1.25 pitch thread. Does your bolt look like this?
    In my car, one of the four has a thread-repair insert with a 1.5 pitch bolt.
  11. The Following User Says Thank You to Cremulator For This Useful Post:
    MB (6th June 2024)
  12. #10
    483 Post(s)
    Apologies, a wee bit munted relaxing tonight, should there be any consideration for strength grade bolts of potential baby ‘safety’ seats in OEM floors…..4.6/8.8/12+ ?
