Page 70 of 77 FirstFirst ... 6869707172 ... LastLast
Results 691 to 700 of 762
Thread: Jay see 1997 GU build up
  1. #691
    May 2016
    lower west victoria
    30 Post(s)
    Quote Originally Posted by MB;845291... Young son will go seriously far, cool, calm & collected humble tutorials [emoji736
    Yeh, he's not bad eh MB. I watched his vid to learn how to do my front axle rebuild.
  2. The Following User Says Thank You to 10G For This Useful Post:
    MB (27th April 2024)
  3. #692
    Contact Milweld in Mansfield. That’s what I have and I love it.
    Has anyone got a contract number for them. I've sent them a Facebook message and an email through their website, but would like to have a chat with them first..
  4. The Following User Says Thank You to jay see For This Useful Post:
  5. #693
    483 Post(s)
  6. #694
    Cheers Mark.
    I did see that, but wanted to speak to millweld directly. I'll call tvs and see if they can get me through.
  7. The Following User Says Thank You to jay see For This Useful Post:
    MB (28th April 2024)
  8. #695
    5741 9112.
  9. #696
    483 Post(s)
    You’re Too Honest @mudski Brother Mills Mrs is going to Love you
    Best to PM & Delete Digits Here Maybe
  10. #697
    483 Post(s)
    @mudski delete post
  11. #698
    So I picked up a cargo barrier off marketplace for $50. Man what a mission. In the end I had to remove the backing of the fridge cage and work out how to mount the bottom of the barrier. Then make up brackets to mount the top and reposition the electrical components as they now sits higher. A fair bit of mucking around because of the draws, but it's now securely in place. I've had to spin the freezer 90 degrees as it didn't fit.
    Managed to also fit a water pump and plumb it to the tank, because of the design it has 2 outlets one on each side. I plumb both sides to one and then to the pump. Didn't quite work, am I asking too much from the pump?
  12. The Following User Says Thank You to jay see For This Useful Post:
    10G (6th May 2024)
  13. #699
    The diaphragm pump has a poor suction capability, which is why they only rate the discharge head. You will do better lowering the inlet of the pump to the same level as the tank outlet, then it should work fine.
  14. The Following 3 Users Say Thank You to PeeBee For This Useful Post:
    10G (6th May 2024), BrazilianY60 (6th May 2024), jay see (6th May 2024)
  15. #700
    Thanks.
    I did try it at a lower level, but probably not long enough to get the air out. It was late and I was getting impatient I will give it another go on the weekend. The bloody shopping trolley is playing funny buggers, just out of the blue it gets irregular revs then stops, starts up fine and keeps going. Did it twice this morning within 15k out of a 45k trip. Ahhh,
  16. The Following User Says Thank You to jay see For This Useful Post:
    PeeBee (6th May 2024)
