Results 1 to 6 of 6
Thread: GU Front hub rebuild. What's this?
    May 2016
    lower west victoria
    30 Post(s)
    Pulled apart the drivers side front hub to replace axle seal and other stuff.
    Was removing the bearings out of the front hub and this fell out:
    It's not a bearing race, it looks like a machined spacer. I can't see where it goes in any of the workshop manuals I've looked at.
    I have a 2013 Patrol, CRD.
    Any thoughts???
    May 2016
    lower west victoria
    30 Post(s)
    Quick update for others. It's called an egg hub spacer ring.
    I've read that it's not required with the auto hubs, only the manual hubs and vice versa. My Patrol has (modified) auto hubs and has that spacer from factory, so I guess it's required.
    Wrong, see below for CORRECT identification.
    177 Post(s)
    Edit: Look like you got it mate. I was wrong about it being the outer race.
    I am curious though about your Auto hub mod that requires the spacer. It's usually just a butcher job prying the auto part out of it to manualize it.
    May 2016
    lower west victoria
    30 Post(s)
    Nope, I got it wrong.
    It's an alignment spacer that sits in the auto hub body. It helps to centre the autohub up with the hub, it stops the autohub slipping around on the hub within the free space provided by the slop/slack with the autohub mounting bolts, the spacer makes it align more precisely.
  5. The Following User Says Thank You to 10G For This Useful Post:
    pollenface (30th March 2024)
    Yes the Egg Ring is about twice that size. Sounds like you have it sorted. Apologies for not being here
    May 2016
    lower west victoria
    30 Post(s)
    Hey, no apology needed. The best thing about solving problems yourself is that you remember what you discover. If you get told, you tend to not remember it as well, that's what happens to me anyway.
    I've never pulled out a CV before, so this entire process is a great learning experience.
  8. The Following 2 Users Say Thank You to 10G For This Useful Post:
    MB (2nd April 2024), MudRunnerTD (2nd April 2024)
