Page 30 of 33 FirstFirst ... 2829303132 ... LastLast
Results 291 to 300 of 330
Thread: Garett's ford maverick 1990,
  1. #291
    Patrol Freak garett's Avatar
    Jan 2015
    north
    21 Post(s)
    new gearbox mounts, most of the exhaust is in place, few more bits to get hold of then i can start fitting up the rest.
    once this is all done i can fix the a/c and rear suspension bushes, deck out the back redo the rear bar.
  2. #292
    Jan 2015
    north
    21 Post(s)
  3. #293
    Apr 2021
    Brazil
    3 Post(s)
    Is the boost electronic controlled on that turbo?
    Is it too big of a turbo for the TD? I noticed it required spacers at the manifold.
  4. #294
    Jan 2015
    north
    21 Post(s)
    the manifold had a t3 size flange the turbo has a t25. needed an adapter to fit.
    i have a mechanical control for the wastegate just not put it on yet.
    i was lead to believe its the correct size ... i guess i will find out in a few weeks.
  5. #295
    Jan 2015
    north
    21 Post(s)
  6. The Following 4 Users Say Thank You to garett For This Useful Post:
    AB (16th March 2024), BrazilianY60 (24th March 2024), MB (18th March 2024), PeeBee (23rd March 2024)
  7. #296
    Jan 2015
    north
    21 Post(s)
    getting closer
  8. The Following 4 Users Say Thank You to garett For This Useful Post:
    BrazilianY60 (24th March 2024), MB (18th March 2024), PeeBee (23rd March 2024), Touses (23rd March 2024)
  9. #297
    Jan 2015
    north
    21 Post(s)
    dump pipe made oh boy is the welding bad, but it seals
  10. The Following 5 Users Say Thank You to garett For This Useful Post:
    BrazilianY60 (24th March 2024), MB (24th March 2024), mudnut (23rd March 2024), PeeBee (23rd March 2024), Touses (23rd March 2024)
  11. #298
    Stress less, welding looks fine Garret Old Mate, don’t forget She’s an oily diesel 4.2TD residue weapon now too
    Did use to have issues on old mild steel radius bend welded Landcrab 2F petrol homemade headers and LPG doing some sort of crystallisation degradation of dodgey welds my nuffy self
  12. #299
    Jan 2015
    north
    21 Post(s)
    well the flange is stainless, radius mild, straight is stainless back to aluminized steel ... i tig welded it.
    getting a bit more done
  13. The Following 2 Users Say Thank You to garett For This Useful Post:
    MB (27th March 2024), PeeBee (27th March 2024)
  14. #300
    Jan 2015
    north
    21 Post(s)
    ok so i'm down to bleeding the fuel system, priming the turbo with oil, adding coolant, oil change, make a coolant bottle, make the intercooler fit somehow. and connect the new senders.
    re run diff breather and vacuum line. move the ac hoses/get the ac working, rear suspension bushes, fit the kitchen make the boxes over the rear guards......
    and now fix the power steering belt tensioner.
  15. The Following 3 Users Say Thank You to garett For This Useful Post:
    BrazilianY60 (29th March 2024), MB (30th March 2024), Touses (29th March 2024)
