Results 11 to 20 of 21
Thread: Engine Cut out.
    Expert NewDan's Avatar
    Oct 2011
    Thanks guys will check on that stuff, just did a 2000k run without it skipping a beat, but I know its still there cause these things don't fix themselves. I think its definatly the ecu cutting the motor cause it always give me a little while to pull over. As long as I get it sorted before tackling the simmo next year should be good.
    Dan
    #1. 2007 Walkabout, Auto, 2" EFS lift, DP chip, 3" Exhaust, cross country intercooler, front and rear diff locks, manual torque convertor lockup, bulbar, IPF driving light, Dawes valve, Boost, EGT and transmission temp gauge, 80 Channel UHF, Black widow storage system, ARB duel wheel carrier. 215 Litre fuel. #2 GQ 95Ti TB42e.
  2. #12
    Swap your ECU relay with your aircon relay and see if that makes a difference
  3. #13
    Oct 2011
    Hey threedogs, yeah I did that, I just went out and bought another relay, it fixed some other problems I had been having but not this problem.
  4. The Following User Says Thank You to NewDan For This Useful Post:
    threedogs (27th April 2014)
  5. #14
    Wollongong, NSW
    Resurrecting an extinct thread here I know but I'm curious if you ever got to the bottom of this? My Patrol has intermittently shown similar symptoms in very similar circumstances.
    Generally happens when starting stationary at a roundabout, then giving it a bit of pedal to sneak in before the next car comes round... hits about 2500rpm then the whole car jerks and accelerator goes unresponsive for a couple of seconds. I take my foot of and gently ease back on and everything is fine again. I haven't ever had it cut out completely afterward. Anyway, after not happening for a couple of months, I got it again today. My scan tool gave me P0087 which apparently means low fuel rail pressure. I can understand the effect, just not the cause. I guess I'll quiz the mechanic when I take it in for a service.
  6. #15
    Expert HV2002's Avatar
    Jan 2014
    Camden South NSW
    Hi terra sounds like you have classic limp mode do you have a boost gauge fitted
  7. #16
    Dec 2015
    WA
    5 Post(s)
    The common element seems to be the roundabout.
    Is it something to do with turn left, then turn right, pretty similar to what you do to demonstrate electronic stability control (I got to shred some tyres at a Holden performance drive day).
    Or fuel surge?
    Graham
  8. #17
    Wollongong, NSW
    No boost gauge...yet. That and EGT gauge are next on the list of additions.
    I picked up some things to check from another thread so I'll start there.
    I know what you mean about the ESC but that effect is much more subtle, besides it gave me the fuel pressure error code and I would expect it wouldn't log that if it were the ESC.
  9. #18
    Quote Originally Posted by terra_australis View Post
    There is a pressure switch on the end of the fuel rail. It can fail. If you go to nissan you havr to buy the complete fuel rail. Theres a few mobs of eBay who sell the switch, its made by bosch btw.
    It could well just be this switch....
  10. #19
    Wollongong, NSW
    Yeah, that's what I was reading about. The car is still under warranty so if it is that at fault, the dealer can sort it out.
  11. #20
    Jan 2024
    Did you ever sort out this problem? If so what was it as I also have same 2 codes. Cheers.
