Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Hard starting 3 litre Common Rail
    Dec 2023
    Thanks MudRunner TD and Cuppa, We had it in to the mechanic and he did a leak test on the injectors. 1 an 3 had very little in the test tube, 2 and 4 were half full after only about 6 seconds. So we are replacing the injectors and hoping for the best.
  2. The Following User Says Thank You to Ontheroadagain For This Useful Post:
    MudRunnerTD (10th December 2023)
  3. #12
    Ballarat, Vic
    178 Post(s)
    Quote Originally Posted by Ontheroadagain View Post
    Good luck, let us know how it goes.
  4. #13
    We tested the priming pump/bulb before, during and after starting and it remains soft. We then tried squeezing the pump 5 to 6 times and it did become hard for about 3 to 4 minutes and then became soft again.
    We took another look at the dashboard for a light, but only see blanking covers on each side of the dash, see photo attached.
    100% air in lines.
    Replace your fuel filter and get a new rubber seal and take care installing it.
    Massive issue if rushed on not done properly as it would bleed air in.
    Once hot and all slightly more expanded your issue is exasibated..
    Dec 2023
    Hi everyone, Well we had the injectors replaced a couple of days ago and the hard starting issues seemed to be completely resolved. Now it starts immediately wether it is hot or cold. My limited understanding is that the 2 and 4 injectors were bypassing enough fuel to cause insufficient rail pressure to start the engine.
  6. The Following 5 Users Say Thank You to Ontheroadagain For This Useful Post:
    BigRAWesty (13th December 2023), Cuppa (8th December 2023), jack (7th December 2023), MudRunnerTD (10th December 2023), mudski (11th December 2023)
  7. #15
    Ballarat, Vic
    178 Post(s)
    Great news! Now back to enjoying your travels.
