Page 217 of 220 FirstFirst ... 215216217218219 ... LastLast
Results 2,161 to 2,170 of 2192
Thread: AB's new GQ is finally here
  1. #2161
    476 Post(s)
    Yeah that changes things big time!
    Bloody kids, who'd have em!
    My kids are now old enough to fend for themselves and don't come away with us anymore! Time to rip out the rear seats in my GU and do as AB has done me thinks!
    AB (20th November 2023)
  3. #2162
    It really does make a heap of extra room.
    Easy bolt off too
  4. #2163
    Hi Team,
    I'm still playing around with trying to fix the nasty wobbles on my GQ, time is difficult lately.
    I'm going to check out King Pin bearings next and I might just replace them anyway.
    I'm not overly keen on just removing a shim like some have done.
    The question I have is if I replace the bearings with the same brand which I assume would be the Koyo's (need to confirm this when checking them) would you need to bother with removing everything inside and checking the preload or would it be fine to just replace with new and go?
  5. The Following User Says Thank You to AB For This Useful Post:
    MB (29th December 2023)
  6. #2164
    Apr 2021
    Brazil
    Bear in mind that even if you replace the king pin bearings, you would still need to gauge the tork with an assortment of shims. So, in my humble oppinion, if your current bearings are good (no marks, smooth turning movements) I would really just re-stack the shims accordingly to achieve the manual load.
  7. The Following 3 Users Say Thank You to BrazilianY60 For This Useful Post:
    AB (7th December 2023), MB (29th December 2023), Stropp (7th December 2023)
  8. #2165
    Thanks mate, I understand the shims and preload so they sit nicely above and below and I understand the shims purpose of machining tolerances of the knuckle in the factory but if they are the exact same brand bearings replaced than surely the bearings are bang on with size and will match the shims already in place to suit?
  9. The Following 2 Users Say Thank You to AB For This Useful Post:
  10. #2166
    Apr 2021
    Brazil
    It could very well be, but honestly, out of coincidence. I wouldn't count on that.
    You see, if one bearing race is pressed a little less onto the knuckle seat, the shimming would be different. Bottom line is, shimming is the final adjustment on a king pin by king pin basis.
  11. The Following 2 Users Say Thank You to BrazilianY60 For This Useful Post:
    AB (8th December 2023), MB (29th December 2023)
  12. #2167
    Eureka!
    I finally solved the nasty wobbles.
    Just replaced the panhard rod bushes and it now drives like a bloody dream!
    They felt fine with no movement but closer inspection showed some wear and they were nolathane too.
    Anyways, Its such a pleasure to drive now!!!
  13. The Following 5 Users Say Thank You to AB For This Useful Post:
    Cremulator (29th December 2023), Maxhead (28th December 2023), MB (29th December 2023), PeeBee (28th December 2023), Touses (29th December 2023)
  14. #2168
    I made up this little tool today which easily removed and installed the bushes too.
  15. The Following 2 Users Say Thank You to AB For This Useful Post:
  16. #2169
    Found a good extrusion that works well with the top radiator today from Clarky.
  17. The Following 2 Users Say Thank You to AB For This Useful Post:
    MB (29th December 2023), PeeBee (29th December 2023)
  18. #2170
  19. The Following 5 Users Say Thank You to AB For This Useful Post:
    jay see (29th December 2023), MB (29th December 2023), PeeBee (29th December 2023), Stropp (30th December 2023), Touses (1st January 2024)
