Results 1 to 10 of 12
Thread: Powered Nutsert tool for the infrequent user
    I have 3 different nutsert tools for metric and imperial nutserts, alum/steel/SS. They can be quite challenging to use at times and require aNutsert tool.jpg lot of grunt to seat. I came across this set-up and it works from a nut driver with the hex drive chuck - absolutely brilliant, simple, effortless and for use up to 10mm steel and SS nutserts.
  2. The Following 4 Users Say Thank You to PeeBee For This Useful Post:
    BrazilianY60 (1st August 2023), jff45 (30th July 2023), MB (30th July 2023), MudRunnerTD (1st August 2023)
    Patrol Freak Touses's Avatar
    Mar 2016
    Childers QLD
    22 Post(s)
    I like it! The hand squeezy jobs are (SHH!) at my age a challenge at times on the bigger diameters.
    Will be keeping a look out for a set.
    https://www.ebay.com.au/itm/155030928117
    Here it is, used it again today, so simple
  5. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    Bidja (31st July 2023), jff45 (31st July 2023)
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    Just put it on my shopping list to order today. That will be 3 different nutsert tools in the drawer. At 78 I'm starting to have trouble pushing the arms together even on the long armed tool with 6mm stainless. I wouldn't try 8mm stainless without putting pipes on the arms and there isn't always room for that..
    John
  7. The Following 2 Users Say Thank You to jff45 For This Useful Post:
    BrazilianY60 (1st August 2023), PeeBee (31st July 2023)
  8. #5
    Patrol God Dhuck's Avatar
    Nov 2010
    Crap Weather State
    5 Post(s)
    You need spinach mate and do the old Popey thing. Forgive me for the old.
  9. The Following 3 Users Say Thank You to Dhuck For This Useful Post:
    BrazilianY60 (1st August 2023), jff45 (1st August 2023), PeeBee (31st July 2023)
  10. #6
    I have a Pnuematic one and it works a treat, will check that out though for sure. I was mounting a shower tent to the side of my caravan a coule of weeks ago and was using big SS Rivets to hold the mounts, me AND my 17yo son were swinging off the poprivet gun together and it nearly killed us both. I have since bought basically the same as yours there but for pop rivets but have not used it yet, the concept seems perfcet in a modern world of 18v everything.
  11. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    PeeBee (1st August 2023)
  12. #7
    Morayfield, QLD
    There was a voucher for $9.90 so got it for $56.09
    John
  13. #8
    Love an ebay voucher!
  14. #9
    What I really like is the 18V tool has the clutch set point so no more thread stripping especially on the mild steel units as its difficult I found to get the seating force correct, especially if moving across from aluminium. This way, you simply let the tool crank up, then it starts to slip when the clutch setting is reached, its either seated or not, adjusted clutch again to do the final tweak. Great device, love it.
  15. The Following User Says Thank You to PeeBee For This Useful Post:
  16. #10
    Morayfield, QLD
    I was watching a YT vid of a guy using one and his method was to not use a clutch and allow the drill itself to start to twist from his hand. He’s obviously not holding the drill too tightly.
    Probably a good idea to play with it on some scrap with the different types of rivnuts to see what works best with your own drill.
    John
