Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 45
Thread: TD rev range opinions.
    334 Post(s)
    Quote Originally Posted by DeanPatrol View Post
    Yes it is a turbo intercooled. THanks all for the replies. My last reply didnt go through for some reason.
    I'll run with my instincts and your replies drive it like a mack truck. As i said i just dont feel this thing liking being revved high im rather surprised the way the mechanic drove it is the way he thinks is the way to get up and go out of it. Patrol needs a few small things done like and ill think of taking it elsewhere.
    I highly recomend a Dyno Tune. You will find it not really making mush boost until 1900 or so and you really are babying it. They Hate 2000rpm, Hate it. 2000rmp is the magic number for a Kettle in my opinion for both my TDs. Cruising ar 2200 to 2400rpm and they just sing. cruisoing at 2000rpm and the EGTs can get a little Hows ya father.
    Once Tuned you could make 4000rpm and the only thing stopping you is your mechanical sympathy. a stock TD42T will be pretty flat through the 3000rpm onwoulds but tuned and there is a power curve up there that they just love.
    Fit it up with a decent Turbo and 12mm pump and nice intercooler (The factory is junk) and it will be transformed. Night and Day mate.
  2. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    Cremulator (14th July 2023), DeanPatrol (17th July 2023)
  3. #12
    Patrol Freak Touses's Avatar
    Mar 2016
    Childers QLD
    22 Post(s)
    Ok, my tuppence worth.
    Although my critter is balanced to within an nth degree it is still a td 42.
    I swap out at 2200, it pulls from 1200 and happily revs right thru to 3000.
    No use revving beyond that, feck all to be gained.
    Upgrade your fuel pump, 11m is fine, big diff to be seen there and with a decent tune naff all difference in fuel consumption.
    Tuppence worth done with.
  4. The Following 2 Users Say Thank You to Touses For This Useful Post:
    jff45 (15th July 2023), MB (14th July 2023)
  5. #13
    482 Post(s)
    TP
    Good & Great 12mm Rarities are few and far between, 11mm are more than enough to achieve anything Australia can safely/wisely/longevity throw at oneself
  6. The Following 3 Users Say Thank You to MB For This Useful Post:
    DeanPatrol (17th July 2023), jff45 (15th July 2023), Rossco (17th July 2023)
  7. #14
    Jul 2023
    Thanks for this insight and taking your time to respond RunMudder. Been doing reading and youre on the money. If it were my daily / camper / off roader id be throwing this car at the mercy of diesel ticklers. But the wifestar drives this daily and it hardly gets warmed up before she gets to work (which is another issue , but thats for another chapter).
    Im content with the power this thing has. And again im ass you ming that tune / power wise it has never been touched judging by receipts. But its NEVER big enough I guess.
    Is it effective to give it a tune whilst retaining factory snail and pump? Its the sort of $ i dont want to throw at it given our scenario and askings of he car.
    If so is there a go to tuner around melbourne? I'm new in town so to speak. I quickly googled and facebooked but got lost quickly in chats regarding fuel screw jockey tuners out there. Im no expert in diesel tuning but fuel screw massaging seems to be a common denominator amongst chats i found to be a BIG no no.
  8. #15
    Jul 2023
    Quote Originally Posted by Touses View Post
    thanks for responding mate. i replied above to mudrunner with more or less same thoughts to your words mate.
  9. #16
    Jul 2023
    Just to clarify...
    When i asked about WHEN do you change gears. I was merely asking WHAT do you rev it to in each gear?
    I hardly go to 2300, somtimes more before dropping it and swapping to next upper cog. RInse and repeat.
    The mechanic in question, @questioned@ this. He revved it to 3k or so, and very quickly shifted before revs had a chance to breathe and drop much at all.
    Nascar td42 pretender there guys. I wasnt buying it.
  10. #17
    Jun 2018
    25 Post(s)
    After I bought my 04 TD42 I took it to Diesel -tec in Lilydale on the recommendation of a few members on here.
    It already had a 3in exhaust, but otherwise stock.
    The tune was pricey, but I have to say well worth it and done by someone who absolutely knows these engines. So the piece of mind was worth it.
    Previous owner had dialed up the fuel screw, so Andy at Diesel-tec increased the boost to match and I achieved much better fuel economy.
    I drive it around town mostly and get about 12.8L/100
  11. #18
    May 2022
    Tai Tokerau, RD8
    15 Post(s)
    Done properly and sympathetically, it can make a positive difference. (I'd always advise a lift-pump, pre-injector-pump as well)
    Consider that these things were assembled to be reliable AF (detuned from factory) and *just a couple* of years ago... a tweak on the smoke screw will usually help.
    It's the "wind it in until you're blowing like a train, then dial back an eighth-turn" muppets that tend to blow motors.
    And as above... EGT gauge will tell you what-for.
    1989 LWB 5-Seat, TD42
  12. The Following User Says Thank You to mihit For This Useful Post:
    MB (19th July 2023)
  13. #19
    482 Post(s)
    Very “Happy” so far with UFI’s 11mm / 18g ‘kit’ (United Fuel Injection) from over in WA after QLD Guru’s recommendations kindly on here
    https://www.unitedfuel.com.au/vehicl...rket-turbo-kit
    Decided to Intercool directly under my highest muddy/river crossing speccy stock bonnet via W2A (water to air) thanks to PWR and their efficient cylinder Hot-Dogs too
    https://shop.pwr.com.au/intercoolers
    Merely 156 rwkw (rear wheel kilowatts) (not flywheel) and a helpful 650 Nm ( Newcastle Mum’s) of hard/slow workable torque
  14. The Following 4 Users Say Thank You to MB For This Useful Post:
    BrazilianY60 (20th July 2023), jff45 (19th July 2023), Rossco (19th July 2023), Winnie (19th July 2023)
  15. #20
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    13 Post(s)
    Are you measuring intake air temps with the W2A? I'm currently converting mine to W2A with Aeroflow gear (IC, pump & heat exchanger) and I'm putting exposed tip thermocouples before & after the IC to see how much difference it makes.
    Apologies to the OP for the hijack..
    John
  16. The Following 2 Users Say Thank You to jff45 For This Useful Post:
    BrazilianY60 (20th July 2023), MB (19th July 2023)
