Results 1 to 10 of 11
Thread: Fuel Consumptions TB42 GQ
    Jun 2023
    HI guys, just a quick question, why is the GQ TB42 carby use half a tank to travel about 100kms but if u tow a trailer like car trailer or van loaded it uses 1/4 of the tank? is there somthing different in the tune side, or a module somewhere altering the system, or the mechanically way its built, ive searched and found nothing about it, so thought id ask you guys here thanks have a great and safe day
  2. The Following User Says Thank You to hellmatic For This Useful Post:
    MB (16th July 2023)
    82 Post(s)
    Sounds a bit back to front, but check your fuel pump pressure and filter or fuel lines for a restriction. I've seen heavy fuel usage in my EFI falcon when the filter was nearly blocked.
    MB (16th July 2023)
    Jun 2023
    i would thought that also matey, checked them, and everything is fine with no missfires,backfire,slugish on power or anything, its just uses more fuel without towing somthing heavy, and i can never figure it out, and its the same way on my dads Nissan Navara D22 1997 QD32 Duel Cab
  6. The Following User Says Thank You to hellmatic For This Useful Post:
    MB (16th July 2023)
  7. #4
    Bananas Speak “Matey”
  8. #5
    How’s About using your hidden Knowledge to potentially Help out a Young Bloke/Lass in Time to come here Brother……’EGO CAN be a dirty SkyHook’
  9. #6
    Jun 2023
    hahah thanks everyone, just thought to try and understand why this happens, could there be somthing in the tuning of the engine, or the way the carby is or even a module placed somewhere that alters somthing, or even the timing of the engine, that makes it perform better at a certain degree angle under load, that makes it more efficient when pulling
  10. The Following User Says Thank You to hellmatic For This Useful Post:
    MB (16th July 2023)
  11. #7
    DO Tell Old Mate
  12. #8
    82 Post(s)
    Maybe check the vacuum advance diaphragm. If it has a hole or small tear, it might only be doing half a job.
  13. #9
    Apr 2021
    Brazil
    Nice catch Mudnut. This makes sense as an engine with less of an advance surelly burns fuel worse than a properly advanced one. If for whatever reason the vacuum advance is working under heavy load but not at light load, that could be it.
  14. The Following User Says Thank You to BrazilianY60 For This Useful Post:
    mudnut (18th July 2023)
  15. #10
    My Deepest Apologies @hellmatic Mate I must’ve had my Tin-Foil hat on again
