Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Water in Airbox
    Have a duck bill rubber thingo drain in my airbox. Could fit one downstream of your tap on a small length of pipe in case you forget to close tap off crossing.
    Hope she keeps hanging in there mate. Sound like u might be lucky.
    https://inhousefabrication.com.au/pr...uckbill-valve/
    Thanks thats what I need , just ordered one.
    Bidja (11th April 2023)
  3. #12
  4. The Following 2 Users Say Thank You to mudski For This Useful Post:
    mudnut (11th April 2023), MudRunnerTD (11th April 2023)
  5. #13
    Thanks Mark. Good info.
    mudski (11th April 2023)
  7. #14
    84 Post(s)
    Good things, but must be inspected and cleaned, often.
  8. #15
    Good point Craig, I recall mine used to fill up with the shit that came in via the snorkle
  9. #16
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    40 Post(s)
    @mudski these Donaldson Vacuator Valves range from 25-78mm dia and the application here is for cyclonic pre filters.
    The smallest (P149099 /P525956_25mm dia) looks very similar to the one in my airbox _ box is of thin wall aluminium fabricated construction and the valve is captivated by the circumferential grove shown for these two valves (Donaldson).
    General info: I live on a dirt road and only ever wiped the inside of box out (installed for several yrs), never had to remove or clean the bib internal profile.
  10. #17
    Correct. These are not originally designed for the aftermarket custom air boxes, but seem to be the best thing to use until someone else comes up with a better idea.
    The difference between the two 25mm vac valves is the thickness of the panel its mated too.
    P149099
    P525956
    FYI. If your air box fills up with water, the vac valve won't just open up, well it may a little under the weight of the water, but when not in use they sit shut. They operate when the engine is running.
    Bidja (12th April 2023)
  12. #18
    sunshinecoast
    the durometer is also different in those two valves . on the donaldson page it describes when to use either one .
  13. #19
    How’d you go with checking out the rods Rossco? All good?
  14. #20
    Yeah haven't, drove back from Mallacoota, over 500k she seemed fine but think I will after Tassie trip. It's going in for a service today so will have a chat to them see what they think or if they've got time to do it. .
  15. The Following User Says Thank You to Rossco For This Useful Post:
    AB (17th April 2023)
