Results 1 to 5 of 5
Thread: Steering column bearings
    Expert Lawrence's Avatar
    St Thomas, Jamaica
    Where would I get steering column bearings to buy for my GQ? There is a creaking sound coming from the column when turning, especially on dry surfaces. I suspect the bearings in the column need grease, but worse case, new bearings. I've checked on popular sites like Amayama, and Parsouq, but they don't seem the sell the internal parts of the column.
    1989 Nissan Patrol DX with the td42 (inline pump). No mods yet except black US 16x8 rims with 265 75 16 Ats
    St Thomas, Jamaica
    Water seems to have gotten into the column from a leak.
    I guess the first thing to determine is whether the bearings are serviceable, meaning they may be sealed for life configuration, and the seals have hardened and the grease dried out. You may be able to force some grease into the bearing elements and stop the noise via the seal but this is a short term solution - then again the loads on them is probably small so you might get away with it. You could if all else fails, and if you can get to the bearings, use a syringe and push the grease into the roller cage - again its desperation stuff. . I would also have a close look to see if you can remove and replace the bearings - they may be in crimped sub assemblies and that will complicate the situation. I think you may end up trying to source a replacement column. I have one but its in Melb Australia, so no help to you. The column isn't that hard to remove, so maybe you would need to remove from the vehicle to assess properly.
  4. The Following User Says Thank You to PeeBee For This Useful Post:
    Lawrence (21st January 2023)
    May 2022
    Tai Tokerau, RD8
    15 Post(s)
    Not sure what's available in jamaica (mon) but here we have engineering and even specialist bearing supply houses. I imagine they're a standard size, but you'll need them out to check for dimensions/ parts number. This will be on the outer race.
    1989 LWB 5-Seat, TD42
  6. The Following User Says Thank You to mihit For This Useful Post:
    Lawrence (24th January 2023)
    May 2022
    Tai Tokerau, RD8
    15 Post(s)
    Nothing is "sealed for life" if you're determined enough
    Most bearings SAY they're greased for life, but it's a simple matter to pop the dust cover off, flush out old grease, and if they're still good, regrease and refit them. I actually make this standard practice with all new bearings before I fit them.
  8. The Following 3 Users Say Thank You to mihit For This Useful Post:
    Lawrence (24th January 2023), MB (21st January 2023), PeeBee (21st January 2023)
