Results 11 to 20 of 33
Thread: Slow refresh of my 92 Safari.
    Sep 2022
    Guam
    Unfortunately the cigarette lighter is also 24v. I've been reading it might be bad to have a draw off of just one battery in a dual battery 24v system. But I'm new to 24v systems so I could be wrong.
  2. #12
    Sep 2022
    Guam
    Installed some Kilmat sound deadener on the floor pan today.
    It took 50sq ft to do the whole floor and a little on the sides. Found a bit of rust just forward of both rear wheel wells. Will have to cut out and replace eventually. But a quick fix for now. Just some rust converter and rattle can. Is that area common for rusting out?
    1992 24v Safari high roof Td42
    1994 Subaru Impreza WRX wagon
    2020 Subaru Forester
    2019 Subaru Ascent.
  3. The Following User Says Thank You to Steve0.adams For This Useful Post:
    BrazilianY60 (28th December 2022)
  4. #13
    Sep 2022
    Guam
    Took the Safari out for some red dirt fun. might have been a little too wet for this clay like mud. I didn't break anything but definitely want to put some lockers in. One of the jeeps wasn't so lucky, broke one of the rear shock mounts.
    Sent from my Pixel 6 Pro using Tapatalk
    2019 Subaru Ascent.
  5. The Following 7 Users Say Thank You to Steve0.adams For This Useful Post:
    BrazilianY60 (28th December 2022), Cremulator (28th December 2022), MB TD42 (17th March 2023), mihit (31st December 2022), mudnut (28th December 2022), Plasnart (28th December 2022), Touses (28th December 2022)
  6. #14
    Apr 2021
    Brazil
    3 Post(s)
    That seems to have been really fun! I'd say the jeep was too lucky to have broken just the mounts, LOL. They are not patrol-strong.
  7. #15
    You’ll convert some of your Jeep mates over to real 4x4s soon hopefully! Looks great.
    Gong him Red!!
  8. #16
    Sep 2022
    Guam
    That would be neat. But I have the only Safari/Patrol on the island. Jeep and Toyota are the primary 4x4s out here.
    2019 Subaru Ascent.
  9. The Following User Says Thank You to Steve0.adams For This Useful Post:
    Plasnart (30th December 2022)
  10. #17
    Sep 2022
    Guam
    I decided to take the super wide fender flares of due to the front left one being broken and flapping in the wind when I drive around. looks like it m in the market for some wheel run repair plates.
    2019 Subaru Ascent.
  11. The Following User Says Thank You to Steve0.adams For This Useful Post:
    Touses (30th December 2022)
  12. #18
    May 2022
    Tai Tokerau, RD8
    15 Post(s)
    Quote Originally Posted by Steve0.adams View Post
    For those that have 24v systems. where are you hooking up your stereo for constat/battery power.
    Theres a converter in the passenger side kick panel that feeds the OEM clock, and the instrument cluster. This has ON/ACC/Constant outputs at 12V. I shitcanned the 30 year old one and replaced it with a beefy 20A (?) one from jaycar. (I run head unit, amp, phone/radio/gps chargers etc off it)
    If you search "DC-DC buck converter" you'll find something.
    Just have to watch as at least one new stereo I've seen (sony I think) has the "constant" (what used to be "memory") power as the main feed, and the ACC is just a trigger. So that would smoke the original converter unless you did some bodgy workaround with relays.
    1989 LWB 5-Seat, TD42
  13. #19
    May 2022
    Tai Tokerau, RD8
    15 Post(s)
    Or do the inverse of what MR says and slap a 12V alternator and battery system in there somewhere for the legacy gear.
    (Just have to remember you need wiring approx twice as big if using half the voltage)
  14. #20
    May 2022
    Tai Tokerau, RD8
    15 Post(s)
    Confucious say:
    If it breaks, Build it stronger.
    If it doesn't, Drive it harder.
